How To Add A Custom Electrical Symbol?
HumbleChief
Go to solution Solved by DBCooper,
  • Solution
The easiest way to get something that acts like something else is start with a copy.  Find the afci outlet in the library and copy it to your user library and then make the changes you need.  If all you want to do is change the label then you can use the edit cad block tool to change the text to whatever you want it to be.
Yeah Coop's got a good point, would be easier to just copy a GFCI from the library and modify it. You original question wasn't clear if you were importing a new 3D model or what, so I just ass-u-me-d. My bad.
Go find a GFCI in the core library, copy it to user catalog, right-click it and hit Edit CAD Block.
The one you'd saved in your library is using a generated CAD Block that looks like the model so you'd have to give it the GFCI CAD block first, then modify it.
