Small boards above roof.
Cadwork22
Go to solution Solved by DBCooper,
  • Solution
  Quote
The side walls on the porch are actually solid railings, shutting of the layer, shuts off the entire wall...
Expand
Not really sure that they need to be (or even should be) solid railings but my guess is that the boards you are seeing are just the wall caps that you can turn off.
