Cadwork22 Posted July 2, 2024 Share Posted July 2, 2024 Auto created a roof, two gable roofs don't have the wall reaching the roof, I think this a simple setting. Thanks, Link to comment Share on other sites More sharing options...
Cadwork22 Posted July 2, 2024 Author Share Posted July 2, 2024 Also, my floor/ceiling isn't showing for loft, see image. Thanks again! Link to comment Share on other sites More sharing options...
Cadwork22 Posted July 2, 2024 Author Share Posted July 2, 2024 Here is my plan file if this helps. ANTHEM.plan Link to comment Share on other sites More sharing options...
DBCooper Posted July 2, 2024 Share Posted July 2, 2024 Your room outside of the stairwell is also marked as an "open below" room type. That is why you don't see a floor. 1 Link to comment Share on other sites More sharing options...
Cadwork22 Posted July 2, 2024 Author Share Posted July 2, 2024 Great thanks! Any ideas on the gables, I tried auto build and default wall top… Link to comment Share on other sites More sharing options...
TeaTime Posted July 2, 2024 Share Posted July 2, 2024 They're there, they're just invisible. You probably tried to delete them at some point, Chief makes them Invisible and sets them on the Walls, Invisible layer when they're needed for things like gables. 1 Link to comment Share on other sites More sharing options...
Cadwork22 Posted July 2, 2024 Author Share Posted July 2, 2024 I tried toggling the wall invisible layer and nothing happened, how were you able to select them? Link to comment Share on other sites More sharing options...
Solution TeaTime Posted July 3, 2024 Solution Share Posted July 3, 2024 Oh they're up on the Attic Floor. Link to comment Share on other sites More sharing options...
Cadwork22 Posted July 3, 2024 Author Share Posted July 3, 2024 Never mind i got it to work, thanks for all the help Link to comment Share on other sites More sharing options...
Cadwork22 Posted July 3, 2024 Author Share Posted July 3, 2024 Last post tonight I promise, the image attached shows a hole in the ceiling that I can't figure out.... My plans are posted above. Link to comment Share on other sites More sharing options...
jmsisco Posted July 3, 2024 Share Posted July 3, 2024 Look at the rooms on the 2nd floor that you have named open below. Looks like all the closets are named open below . Open below put hole in ceiling. change the room names for the closets shower and hall area Link to comment Share on other sites More sharing options...
Cadwork22 Posted July 3, 2024 Author Share Posted July 3, 2024 Perfect thank you Link to comment Share on other sites More sharing options...
