John_B Posted June 30, 2024 Share Posted June 30, 2024 I'm trying to help a GC understand this drawing (not mine) because I believe that it is not code compliant...when I try to draw this in Chief it won't allow such a tight radius and when I look at the code, it appears that at the "walking line" which is defined as 12" from inner radius, the tread should be 10" minimum....am I missing something here? Link to comment Share on other sites More sharing options...
ACADuser Posted June 30, 2024 Share Posted June 30, 2024 Your walk line is at 2'-5". If you measure the tread at 12" out front the inner radius the tread will be less than 10". That's my best guess. I'm nut sure Chief is preventing this due to code. Link to comment Share on other sites More sharing options...
John_B Posted June 30, 2024 Author Share Posted June 30, 2024 1 hour ago, ACADuser said: Your walk line is at 2'-5"..... On this drawing it is, however, my interpretation of the code is 12" from the inner radius is where the walk-line should be measured, not what is shown here at 2''-5"... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 30, 2024 Share Posted June 30, 2024 That stair wold only be compliant if the inside radius was increased to about 4-1/2 feet. The line shown by chief with the arrow isn't the "Walk Line" as required be code. The other option would be to decrease the number of treads so that the minimum tread width at the walk line (12" from inside) would be 10" minimum. Link to comment Share on other sites More sharing options...
ACADuser Posted June 30, 2024 Share Posted June 30, 2024 Like this: Link to comment Share on other sites More sharing options...
Hammer7 Posted July 1, 2024 Share Posted July 1, 2024 Make sure your in the right code section for spiral stairs if indeed that is what they are going for. Spiral stairs have a separate section. Link to comment Share on other sites More sharing options...
para-CAD Posted August 14, 2024 Share Posted August 14, 2024 At the 12" walkline the tread should be 10" or greater. It's only 8 ¼". You're right to suspect these stairs. Link to comment Share on other sites More sharing options...
