IRDesign Posted June 19, 2024 Share Posted June 19, 2024 For some strange reason the door swing indicators on my door schedule is showing a brick pattern. I've spent way too much time trying to figure it out. Has anyone else run into this? This doesn't show on the actual elevation, only in the 2D door on the schedule. I'm stumped. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 19, 2024 Share Posted June 19, 2024 I would say it may have something to do indirectly with this situation that also has not been resolved. Worth referencing anyway if you end up making a tech support call. Link to comment Share on other sites More sharing options...
VHampton Posted June 20, 2024 Share Posted June 20, 2024 Interesting... In looking at both issues, they've got the same running bond. What happens if the pattern gets changed? Maybe try opening an archived plan and layout. It's easy to copy and paste them onto the Desktop for quick exploration. Changing the siding pattern to something else. If it doesn't act up... that's a good sign. Use a different brick pattern rather than the basic running bond w/o grout joints. Link to comment Share on other sites More sharing options...
robdyck Posted June 20, 2024 Share Posted June 20, 2024 Perhaps it could be as simple as turning off the 3d Patterns layer for the layer set used in the view with the schedule? Just a thought... Link to comment Share on other sites More sharing options...
