EsteeChief Posted May 29, 2024 Share Posted May 29, 2024 Hello, How can I have the dimensions from centre to center of the wall... Going crazy. trued everything.. I'm sure it's so simple but I cannot see it. Thanks 1 Link to comment Share on other sites More sharing options...
Solution Chopsaw Posted May 30, 2024 Solution Share Posted May 30, 2024 I am not sure you can auto dimension exterior walls to the center of framing but you can certainly move you dimension snaps to that location if you set it to. Link to comment Share on other sites More sharing options...
basketballman Posted May 30, 2024 Share Posted May 30, 2024 Question is: Why would you want to; especially for new walls when framer needs dimensions to either side; not to middle ... 1 Link to comment Share on other sites More sharing options...
para-CAD Posted May 30, 2024 Share Posted May 30, 2024 YESSS!! Thank you for pointing out the framer. I know center to center is the same as over to it, but over to it on the plans just looks right. (Former framer) 1 Link to comment Share on other sites More sharing options...
basketballman Posted May 30, 2024 Share Posted May 30, 2024 25 minutes ago, para-CAD said: YESSS!! Thank you for pointing out the framer. I know center to center is the same as over to it, but over to it on the plans just looks right. (Former framer) Thank you ! ( from another former framer ) Link to comment Share on other sites More sharing options...
EsteeChief Posted June 2, 2024 Author Share Posted June 2, 2024 Ok. I now know how. If I zoom in all the way it picks up the Center. Thank you all Link to comment Share on other sites More sharing options...
