Cadwork22 Posted May 24, 2024 Share Posted May 24, 2024 Is it possible in chief to create stone footing like the picture attached? Thanks in advance. Michael Link to comment Share on other sites More sharing options...
para-CAD Posted May 24, 2024 Share Posted May 24, 2024 I think David Michael has columns with stone under them like that. Link to comment Share on other sites More sharing options...
Doug_N Posted May 24, 2024 Share Posted May 24, 2024 7 hours ago, Cadwork22 said: Is it possible in chief to create stone footing like the picture attached? Thanks in advance. Michael I think you mean the column base or pedestal, not a footing. You can create your own by choosing a suitable column and then creating a solid shape under the column (or in this case, set of columns) and then painting the stone surface on the solid. Link to comment Share on other sites More sharing options...
Cadwork22 Posted May 24, 2024 Author Share Posted May 24, 2024 Thanks, would you use a slab to create the shape? Link to comment Share on other sites More sharing options...
Doug_N Posted May 24, 2024 Share Posted May 24, 2024 1 hour ago, Cadwork22 said: Thanks, would you use a slab to create the shape? A slab or a 3d solid. Either will work. 1 Link to comment Share on other sites More sharing options...
winterdd Posted May 24, 2024 Share Posted May 24, 2024 3d solids for column bases and apply whatever material you want. I use a lot from Bueshel Stone Corp in the catalog. 2 Link to comment Share on other sites More sharing options...
VHampton Posted May 25, 2024 Share Posted May 25, 2024 Geometric shapes. There's a tapered base just like that. The house that you're working has some close relatives in the samples galleries, but the bases aren't tapered. It's a common detail in Craftsman Style architecture. You may want to take a visit there as well... just to see the details etc. Good stuff. https://www.chiefarchitect.com/products/samples.html 1 Link to comment Share on other sites More sharing options...
