Renerabbitt Posted May 21, 2024 Share Posted May 21, 2024 What are you using it for? what can you do with this? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 21, 2024 Share Posted May 21, 2024 I don't use it. It could be useful if you wanted to write a macro (on the fly) and save it into the scripts folder - or something similar in the data folder. But really it's just used by Chief internally to know where to get things. Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 21, 2024 Author Share Posted May 21, 2024 1 hour ago, Joe_Carrick said: I don't use it. It could be useful if you wanted to write a macro (on the fly) and save it into the scripts folder - or something similar in the data folder. But really it's just used by Chief internally to know where to get things. can you tell me more? I have no clue as to what it even is Link to comment Share on other sites More sharing options...
BenMerritt Posted May 21, 2024 Share Posted May 21, 2024 The LOAD_PATH variable is used with Ruby's "require" function, which loads an external script file into the current Ruby process. Those script files can contain basically any valid Ruby code, which makes for a convenient place to put helper classes and so forth. 2 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 22, 2024 Share Posted May 22, 2024 To elaborate on Ben's statement: ".rb" files can be stored there and "required". I think the Ruby "Tutorial" is one such file. Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 22, 2024 Share Posted May 22, 2024 There was a gentleman last year who had to manage many macros and users, and decided instead of putting them in the template files, and perhaps copying them between templates, to instead put them in their own .rb file in this directory. That way if he had to make an update, people would not need to update every plan that they were working on to get the newer macro results. he would just copy the new rb file to their directory Downside is, if one opened an older file which at the time, had a different result from that macro which maybe has been changed three times since that older file was last opened, you would be unable to obtain the original result without having to go into the directory and revert to the macro file of the day that older file was printed. So one has to assess, how often that downside would occur. or perhaps manage it another way, like creating a new macro if an update to a macro would have a material difference to older files, or worse would break because there is a new parameter that was not available at the time Or I suppose if you were really really diligent you would incorporate some sort of versioning on the execution of that macro Link to comment Share on other sites More sharing options...
