mtldesigns Posted May 17, 2024 Share Posted May 17, 2024 How do create and use a custom structural shape? I need to use z-channels in lie of the C's on this exterior wall. Interior wall are good with the C's. I am not finding a lot of guidance... but as it usually goes, it's probably right in front of my face. Actually, I already created the profile, but not clear on how I can use as an option in DBX Thanks in advance Link to comment Share on other sites More sharing options...
robdyck Posted May 17, 2024 Share Posted May 17, 2024 You won't be able to replace that c-channel in the wall dbx. If you want to model a z-channel, you'll need to add them manually. Link to comment Share on other sites More sharing options...
rgardner Posted May 17, 2024 Share Posted May 17, 2024 14 hours ago, mtldesigns said: How do create and use a custom structural shape? I need to use z-channels in lie of the C's on this exterior wall. Interior wall are good with the C's. I am not finding a lot of guidance... but as it usually goes, it's probably right in front of my face. Actually, I already created the profile, but not clear on how I can use as an option in DBX Thanks in advance 3 hours ago, robdyck said: You won't be able to replace that c-channel in the wall dbx. If you want to model a z-channel, you'll need to add them manually. As Robert says the framing profiles are hard coded so if it is something you need please make a concise suggestion with the reasoning of why it would help your workflow. In the meantime you can make the wall with an invisible framing layer and then do a room molding polyline with the framing members as a vertical molding. Or manually place symbols. All that being said. Is this something you need to show in 3d or can a cad detail suffice? Link to comment Share on other sites More sharing options...
mtldesigns Posted May 18, 2024 Author Share Posted May 18, 2024 8 hours ago, rgardner said: Is this something you need to show in 3d or can a cad detail suffice 11 hours ago, robdyck said: You won't be able to replace that c-channel in the wall dbx. If you want to model a z-channel, you'll need to add them manually. Thanks gents, I kind a figured as such. This is the client I mentioned in another post, in regarding wanting "shopping list" per say. I should be able to create a material of the the Z's, but still show as a channel, so that he can get that count. My CAD detail will show the correct config. Link to comment Share on other sites More sharing options...
