Kanomis Posted May 1, 2024 Share Posted May 1, 2024 Good afternoon, Concern # 1: I can't seem to figure out why I have a short section of wall above my porch beams. This has not happened in the past when I have created porches with beams. All of my ceiling heights match. When I try changing the porch ceiling height, it blows everything up. Thoughts? Concern #2: After changing some wall dimensions, the gable below has suddenly dropped from the desired 12/12 to something like a 4/12. The setting still show it as 12/12 but its stuck at the lower pitch. Can't seem to figure out why it's refusing to go back to 12/12. Plan file attached. Any thoughts are greatly appreciated, as always! Thank you! New Compressed (zipped) Folder.zip Link to comment Share on other sites More sharing options...
BenPalmer Posted May 1, 2024 Share Posted May 1, 2024 Your supplied Chief file is empty. This is typically a result of zipping the file while the file/plan is open. Close the plan, then zip and upload. Link to comment Share on other sites More sharing options...
Kanomis Posted May 1, 2024 Author Share Posted May 1, 2024 Oops. Thanks for pointing that out! New zip attached. New Compressed (zipped) Folder.zip Link to comment Share on other sites More sharing options...
BenPalmer Posted May 1, 2024 Share Posted May 1, 2024 This is how it opens for me...looks like you fixed it. Link to comment Share on other sites More sharing options...
Mark3D Posted May 1, 2024 Share Posted May 1, 2024 Your roof has a heel height of 12" i think that is making that small wall above the beam Link to comment Share on other sites More sharing options...
Kanomis Posted May 2, 2024 Author Share Posted May 2, 2024 I just tricked it into working. I had to push the wall of that gabled section out 1/4" and that seemed to disconnect it from the porch walls, releasing it from matching the porch pitch. Now I have the wall that's a random 1/4" deeper. Is there something I mistakenly did wrong? And yes, I realized that my heel height was making the strange section above the porch beams. Is it possible to manipulate only the porch heel setting, instead of lowering the whole house? Thanks! Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 2, 2024 Share Posted May 2, 2024 13 hours ago, Kanomis said: And yes, I realized that my heel height was making the strange section above the porch beams. Is it possible to manipulate only the porch heel setting, instead of lowering the whole house? I dont think so, normally I will select the "minority" roof plans and use transform replicate to lower them using the z adjust Link to comment Share on other sites More sharing options...
Kanomis Posted May 6, 2024 Author Share Posted May 6, 2024 Thanks everyone. Link to comment Share on other sites More sharing options...
