desperate need for roof
Cadwork22
Go to solution Solved by Mark3D,
I didn't get any errors either but I did see some problems with how you setup your rooms and a wall alignment issue.   I really can't think of a reason why you couldn't use auto roofs with this plan and even auto rooms.  All I think you need to do is build the second floor exterior walls to match the first floor ones and then just designate the big room as "open below" and then you probably wouldn't need to mess around much with the rooms.
See if this basic tech article helps:
https://www.chiefarchitect.com/support/article/KB-00078/creating-an-open-below-room.html
