agriffiths Posted April 19, 2024 Share Posted April 19, 2024 Morning Everyone! Here's a stumper I've never encountered before!! I built my walls as usual, added my windows and door, added my roof using auto build (I'm not really worried about what it actually looks like) and this happened! i went in and messed around with some values, changed the walls, changed the room definition, no budge. Any ideas what I'm doing wrong? ChiefSupport.planFetching info... Link to comment Share on other sites More sharing options...
Gawdzira Posted April 19, 2024 Share Posted April 19, 2024 select your walls and check this button Link to comment Share on other sites More sharing options...
ericepv Posted April 19, 2024 Share Posted April 19, 2024 Open the DBX for each wall, in the 'Structure' tab click on 'Default Wall Top Height' in the 'Default Wall Heights' section. Link to comment Share on other sites More sharing options...
agriffiths Posted April 19, 2024 Author Share Posted April 19, 2024 @Gawdzira@ericepv - Thank you both! Why would that turn off from project to project? I don't touch those things.. Link to comment Share on other sites More sharing options...
rgardner Posted April 19, 2024 Share Posted April 19, 2024 On 4/19/2024 at 12:08 PM, agriffiths said: @Gawdzira@ericepv - Thank you both! Why would that turn off from project to project? I don't touch those things.. Expand When you manually adjust walls which 99.5% of the time is not necessary and is highly discouraged to do, it will turn off the parametric features of the wall because it thinks you dont want the program to change what you did. So at some point you grabbed that wall and dragged it up. 1 Link to comment Share on other sites More sharing options...
agriffiths Posted April 19, 2024 Author Share Posted April 19, 2024 huh.. I'll have to keep an eye on that! Thank @rgardner Link to comment Share on other sites More sharing options...
