Chiefnewell Posted April 13, 2024 Share Posted April 13, 2024 i AM TRYING TO CREATE OPEN ROOF TRUSSES. SPAN THE WHOLE 40 FT THEN EAVES. ABOVE THE PROTE CO CHERE i WANT TO BE ABLE TO SEE THE TRUSSES IN THE OPEN END. IS THIS POSSIBLE? REGARDS, chiefnewell chiefarchitect x15 shop 8.plan Link to comment Share on other sites More sharing options...
robdyck Posted April 13, 2024 Share Posted April 13, 2024 In your mind, what is an "open roof truss"? As for building trusses, have you tried it? The first steps would be to check 'trusses' in the roof dialog, and then build the roof framing. Link to comment Share on other sites More sharing options...
para-CAD Posted April 14, 2024 Share Posted April 14, 2024 Link to comment Share on other sites More sharing options...
SNestor Posted April 14, 2024 Share Posted April 14, 2024 The carport ceiling height value should be the same as the shop...which it isn't. 1 - Correct the ceiling height. 96.625 for the carport ceiling. 2 - select both roof planes, open them and on the "general" tab, change the value to "trusses". 3 - Now, in the same dialogue...move to the "structure" tab, select "build roof framing". You should get roof trusses. The gable end wall above the carport is invisible because the wall on the 1st level is invisible. Link to comment Share on other sites More sharing options...
Chiefnewell Posted April 15, 2024 Author Share Posted April 15, 2024 Thank you for your help. Newell Link to comment Share on other sites More sharing options...
