ChiefUserAndrew8 Posted April 13, 2024 Share Posted April 13, 2024 As the title says, what is this and how can I fix it? The opposite side has the same issue, but larger. Link to comment Share on other sites More sharing options...
Gawdzira Posted April 13, 2024 Share Posted April 13, 2024 What is the ceiling height of the room? That is likely the top plate. By uploading the .plan file this would be easier to ascertain. You must close the program before zipping the file. Also, if you build framing for the walls and roof it may reveal more to you. 1 Link to comment Share on other sites More sharing options...
ChiefUserAndrew8 Posted April 13, 2024 Author Share Posted April 13, 2024 Hello, I suspected as much and would like to denote it in my details. I've attached the plan here so you can confirm what it is. Thank you! Plan.zip Link to comment Share on other sites More sharing options...
robdyck Posted April 13, 2024 Share Posted April 13, 2024 17 minutes ago, ChiefUserAndrew8 said: I've attached the plan here The file can not be open when you attach it. Link to comment Share on other sites More sharing options...
ChiefUserAndrew8 Posted April 13, 2024 Author Share Posted April 13, 2024 How do I upload a file you can use? Link to comment Share on other sites More sharing options...
robdyck Posted April 13, 2024 Share Posted April 13, 2024 Make sure it is closed, then attach it. Link to comment Share on other sites More sharing options...
ChiefUserAndrew8 Posted April 14, 2024 Author Share Posted April 14, 2024 shed.plan Link to comment Share on other sites More sharing options...
Solution SNestor Posted April 14, 2024 Solution Share Posted April 14, 2024 You are using an "elevation" camera which will show everything to "infinity"....I think what you are seeing is the top portion of the 1x gutter fascia. You may want to use a "back clipped" section camera...it shows things from the start of the camera to the end point you drag to. If you turn on the layer "framing, wall" in the camera view layer set (and you build wall framing) you won't see that piece because the studs in front of it will block it. see screen clip below...this is your camera with "Framing, wall" turned on the camera view layer set. 1 Link to comment Share on other sites More sharing options...
ChiefUserAndrew8 Posted April 15, 2024 Author Share Posted April 15, 2024 Much appreciated, I have generated my framing, but was unaware why it wasn't in that view. Link to comment Share on other sites More sharing options...
