GeneDavis Posted April 5, 2024 Share Posted April 5, 2024 Just watched one of @Renerabbitt's excellent YouTube videos, the one about numbering cabinets in install sequence to help with delivery and installation, and he shows towards the end how he has his fillers, a cabinet-category item type, in a separate schedule. He does not show how this separate schedule gets generated, and I'd like to know. In my example I want to schedule all bathroom cabinetry separately from kitchen. So, how does one do this? Link to comment Share on other sites More sharing options...
DBCooper Posted April 5, 2024 Share Posted April 5, 2024 You could create two schedules and use the room filter. This only works if you don't need to combine cabinets from multiple rooms. If you need multiple rooms, then you can create custom categories and filter the schedule by object categories. See if this tech article helps: https://www.chiefarchitect.com/support/article/KB-03120/creating-custom-schedules.html Link to comment Share on other sites More sharing options...
tundra_dweller Posted April 5, 2024 Share Posted April 5, 2024 Rene also uses a pretty complex proprietary macro system to generate many of his schedules, so he's able to get some results that we can't really get OOTB without having the macro skills, which I do not unfortunately. Link to comment Share on other sites More sharing options...
Renerabbitt Posted April 5, 2024 Share Posted April 5, 2024 2 hours ago, GeneDavis said: Just watched one of @Renerabbitt's excellent YouTube videos, the one about numbering cabinets in install sequence to help with delivery and installation, and he shows towards the end how he has his fillers, a cabinet-category item type, in a separate schedule. He does not show how this separate schedule gets generated, and I'd like to know. In my example I want to schedule all bathroom cabinetry separately from kitchen. So, how does one do this? Fillers and partitions are there own category, so just remove them from the cabinet schedule and include them in another schedule but remove base/full/wall cabinets Link to comment Share on other sites More sharing options...
