Pkbldr Posted March 3, 2015 Share Posted March 3, 2015 I have a bathroom model with a partially barrel vaulted ceiling (curved ceiling plane) as shown in the attached jpg. I want to apply a wood plank material to the barrel portion and leave the flat ceiling (flat ceiling plane) as is (white drywall). None of the material painter options allow me to do this but rather apply material to all of the ceiling. If I uncheck Ceiling Finish in the Ceiling Plane specification so that the Materials becomes active, the curved ceiling disappears. How may I isolate the curved ceiling plane to apply the wood material to it alone? Thanks, Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 4, 2015 Share Posted March 4, 2015 The curved part of the ceiling is either a poly-line solid or molding profile and whatever it has, it also has a "Specification Dialog - Materials Tab". Use that to set and orientate the material for that and set the flat ceiling via its room dialog - Materials Tab. DJP Link to comment Share on other sites More sharing options...
Pkbldr Posted March 4, 2015 Author Share Posted March 4, 2015 The curved part of the ceiling is a "Ceiling Plane" with the "Curved Roof" attribute checked. The "Ceiling Plane Specification" dialog "Materials" tab is blank and I learned that the materials are defined by the "Room Ceiling Finish" unless you uncheck this option on the "General" tab of the "Ceiling Plane Specification" dialog. When I uncheck it the ceiling plane disappears, thus my dilemma. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted March 4, 2015 Share Posted March 4, 2015 You could try this, set the ceiling material to your wood plank. Create a shelf or soffit and apply this to the underside of the flat portion, make these materials the other ceiling finish. You may need to adjust their thickness to obscure the wood planks. Graham Link to comment Share on other sites More sharing options...
kMoquin Posted March 4, 2015 Share Posted March 4, 2015 Post the plan. Link to comment Share on other sites More sharing options...
dshall Posted March 4, 2015 Share Posted March 4, 2015 On 3/4/2015 at 5:03 PM, kMoquin said: Post the plan. The obvious path to the solution. Link to comment Share on other sites More sharing options...
Pkbldr Posted March 4, 2015 Author Share Posted March 4, 2015 Here's the plan. Thanks Raney Barrel-2 (1).planFetching info... Link to comment Share on other sites More sharing options...
dshall Posted March 4, 2015 Share Posted March 4, 2015 On 3/4/2015 at 8:05 PM, Pkbldr said: Here's the plan. Thanks Now wasn't that simple, post the plan and you will have an answer in about 45 seconds. Select ceiling plane open DBX, uncheck USE ROOM CEILING FINISH, go to MATERIALS TAB, select material and all is well. Link to comment Share on other sites More sharing options...
Pkbldr Posted March 4, 2015 Author Share Posted March 4, 2015 That's what I want! This is what I get when I do that. Obviously I'm doing something wrong but I cant see it Link to comment Share on other sites More sharing options...
Pkbldr Posted March 4, 2015 Author Share Posted March 4, 2015 This is what my Ceiling Plane DBX looks like Link to comment Share on other sites More sharing options...
dshall Posted March 4, 2015 Share Posted March 4, 2015 On 3/4/2015 at 8:14 PM, Pkbldr said: That's what I want! This is what I get when I do that. Obviously I'm doing something wrong but I cant see it You are using the wrong camera.... you are using a floor camera, I do not believe the floor camera shows ceilings. Learn the difference between the different cameras. Link to comment Share on other sites More sharing options...
dshall Posted March 4, 2015 Share Posted March 4, 2015 On 3/4/2015 at 8:20 PM, dshall said: You are using the wrong camera.... you are using a floor camera, I do not believe the floor camera shows ceilings. Learn the difference between the different cameras. I retract that statement. I do not know what you are doing wrong, must be the wrong camera..... I took your plan, did nothing but change that particular ceiling DBX info and it worked for me. Link to comment Share on other sites More sharing options...
dshall Posted March 4, 2015 Share Posted March 4, 2015 You must have CEILING PLANES and CEILING SURFACES turned off in your camera mode. Link to comment Share on other sites More sharing options...
Pkbldr Posted March 4, 2015 Author Share Posted March 4, 2015 BINGO! We've got a winner! I wonder why it will show the flat ceilings but not the curved one. On the other hand it does show the curved ceiling too until I apply a different finish. Not very intuitive...No Matter...I know it does it now. As always; this forum is one of the primary reasons CA is as successful as it is. Thank you Scott! Link to comment Share on other sites More sharing options...
Solution Pkbldr Posted March 4, 2015 Author Solution Share Posted March 4, 2015 Well for whatever reason it does not show up with the Floor camera but does with the Full camera. Link to comment Share on other sites More sharing options...
