.DWG drawings to walls
buildinthevoid
You can import the CAD into Chief and then use it as a template to draw over. Be sure to turn on object snap when you draw your walls.
There is also a feature called CAD to walls on Chief. I've never used it but this article from the knowledge base is worth a look. https://www.chiefarchitect.com/support/article/KB-00170/using-cad-to-walls-from-an-imported-dwg-dxf.html
  • 4 weeks later...
