Cadwork22 Posted March 30, 2024 Share Posted March 30, 2024 I have a set of stairs; my client wants a pantry on the other side of the stairs that extends beneath the stairs, so one room. How can I close up this wall without covering up the area between the stairs? Thanks. Link to comment Share on other sites More sharing options...
SHCanada2 Posted March 30, 2024 Share Posted March 30, 2024 I do not understand the request and/or cannot visualize it. I'm not sure what "without covering up the area between the stairs" mean Link to comment Share on other sites More sharing options...
Cadwork22 Posted March 30, 2024 Author Share Posted March 30, 2024 If you look at the image, there is an opening on the other side of the stairs, I need to close that without impeding the space under the stairs. So there with be one big one room, the pantry + the understair area. Thanks, Michael Link to comment Share on other sites More sharing options...
Cadwork22 Posted March 30, 2024 Author Share Posted March 30, 2024 I found the glass house rendering to see exactly what I need to cut out. The forums suggested using the Inserts Into Wall tool, which I can't find in the menus. I am in the 3d cam view to see the wall. Is there a 3d polyline I can use? Thanks. Link to comment Share on other sites More sharing options...
SHCanada2 Posted March 30, 2024 Share Posted March 30, 2024 1 hour ago, Cadwork22 said: If you look at the image, there is an opening on the other side of the stairs, I need to close that without impeding the space under the stairs why not put a wall there? Link to comment Share on other sites More sharing options...
Cadwork22 Posted March 30, 2024 Author Share Posted March 30, 2024 I did but I need to cut out the section beneath the stairs. Link to comment Share on other sites More sharing options...
Cadwork22 Posted March 30, 2024 Author Share Posted March 30, 2024 finally got it, thanks for the help everyone. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 30, 2024 Share Posted March 30, 2024 2 hours ago, Cadwork22 said: I did ( Put a wall there ) but I need to cut out the section beneath the stairs. Not sure what you did since you didn't share but editing the Wall Polyline in an Elevation camera, ie break where needed and pull bottom up in this case, same method as you would do a Stepped Foundation Wall, is how I've always done this. https://www.chiefarchitect.com/videos/watch/402/stepping-a-foundation.html?playlist=85 M. Link to comment Share on other sites More sharing options...
Michael_Gia Posted March 30, 2024 Share Posted March 30, 2024 I think what OP needs to do, which Solver alluded to in his wonderful cryptic fashion, is to build the new wall to create the pantry, but then making an opening in the wall under the stair using a pass-through. He just has to shape the pass-through in the triangular shape to fully open access under the stairs. However, this is all guesswork. Link to comment Share on other sites More sharing options...
