tkwebster Posted March 20, 2024 Share Posted March 20, 2024 Hello! I recently got a new computer and everything is backed up to OneDrive. Normally, the process of installing Chief on a new computer has been easy in the past...but not this time. I'm not sure what I have done or what the issue is. All catalogs show up under the Library Browser except my User Catalog. I have even tried importing it manually from the OneDrive location but it just says nothing was imported. I am also getting these error codes: LibraryDatabaseInterface.cpp(465): Error #272032176 "Error Updating Library Schema in User_Library: Database Error: Unable to prepare statement: no such table: LibraryObjects" 03/20/2024 03:16:17 PM Build: 25.3.0.77 Windows 64-bit Unable to prepare statement: no such table: LibraryObjects" 03/20/2024 03:16:17 PM Build: 25.3.0.77 Windows 64-bit Any help would be greatly appreciated! Link to comment Share on other sites More sharing options...
ericepv Posted March 20, 2024 Share Posted March 20, 2024 When I got my new system, I used Zinstall, everything came over without issue Transfer Programs and Files to New Computer, to Windows 11, Windows 10 - Zinstall As a manual install did not work for you (from a thumb drive??), perhaps you should contact tech support. Link to comment Share on other sites More sharing options...
DBCooper Posted March 20, 2024 Share Posted March 20, 2024 Might want to check out these tech articles: https://www.chiefarchitect.com/support/article/KB-00001/backing-up-chief-architect-content.html https://www.chiefarchitect.com/support/article/KB-00091/restoring-chief-architect-content.html If that doesn't help, I would contact tech support. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 21, 2024 Share Posted March 21, 2024 5 hours ago, DBCooper said: Might want to check out these tech articles: https://www.chiefarchitect.com/support/article/KB-00001/backing-up-chief-architect-content.html https://www.chiefarchitect.com/support/article/KB-00091/restoring-chief-architect-content.html If that doesn't help, I would contact tech support. I would suggest moving Chief out of Documents and thus out of OneDrive's automatic Backup of Documents "reach" and another way to go..... OD is a curse in Windows 11, I've had numerous issues with it since switch from Win 10, Chief really should not be using that Folder by default any longer , IMHO https://www.chiefarchitect.com/support/article/KB-03132/resolving-unexpected-behavior-on-a-windows-pc-by-redirecting-the-data-folder.html I've also had several Client's on Mac's having Issues too with either iCloud and also Dropbox , which is enabled by default on some versions of MAC Os. https://www.chiefarchitect.com/support/article/KB-03116/resolving-unexpected-behavior-on-a-mac-by-redirecting-the-data-folder.html M. Link to comment Share on other sites More sharing options...
