Beautiful Chief Architect Rendering using an Image instead of the Backdrop X15 & X16
Steve_Nyhof
On 8/8/2024 at 5:08 PM, blueriver said:
Stevenyhof, i came across this thread looking for brick downloads - thank you for posting this - beautiful renderings and super helpful!! i am looking for more realistic light colored brick downloads (i do a terrible job importing!) do you by chance have any?
I use the brick in Chief mainly for simple jobs, but for remodeling, I take a picture of the clients brick wall and put it into Pix Plant 5 and create my own materials. That is the best way to show off your model to a client - who has brick.
https://www.pixplant.com/
  • 1 month later...
On 3/16/2024 at 11:32 PM, stevenyhof said:
I am including a library of 2D trees that you can use for shadow trees instead of 3D trees. I want to give Rob Dyck a shout out for showing me how to make 2D material images with a solid vertical face and 2D tree images as a way to cast shadows without the added file size of 3D trees.
Here is the Library for the 2D Tree Shadows
https://drive.google.com/file/d/1XJo7gJ9_KXpR-Pp0COgzfKdpmXtVjPE_/view?usp=sharing
Here you can see I am including both deciduous and evergreen trees. Rotate, resize and/or double them up to get the affect you want.
The red rectangle shows where you would capture the image on the screen.
Hi Steve
I really like your renderings and techniques you use plus the hints and tips you offer is amazing thank you so much for sharing.  I've been using CA for a few years and now have upgraded to X16 several months ago.  However I had a virus in my computer a few days ago and lost lots of file etc including my X16.   I had to redownload x16 and for some reason  the tools and template are a little different from the X16 I had a week ago
Anyway my renderings are not as precise and clear as yours - this is the system I have
Chief Architect Premier X 16
ALIENWARE LAPTOP
NVIDIA GRAPHICS 3070 laptop GPU - DIRECT X12
AMD RYZEN 7
Chief Architect Premier x15
Chief  Architect Premier X 11
Chief Architect Premier x 10
home designer pro
.....and before the virus I had pretty good renderings- but not near as clear as yours. I had downloaded your 3D images etc  and backdrops to my system and lots of other interesting info ( all lost)  now I don't know how I did your  downloads nor how I got them in to my user library
if you have any suggestions   -  also how do  you get such good great finishes.  the white house above looks amazing!!! love the tree shadows and how the scenery image  works for you
thank you again its really good to see only CA renderings as opposed to adding another software.. If I seem like I'm all over the place I probably am!!!
Many thanks
Levina
Hi Levina,
By the time you read this you probably have figured some things out. Any libraries I offer can be downloaded and dragged into your CA to load them into your library. Then just rename them to what you want.
Highly recommend that as you build up your library that you back them up. Typically one by one to a folder so you can always put it back if something goes wrong. As you make changes to the libraries, back them up again. Typically you cannot back up the whole User Library, so back them up as individual folders with their respective subfolders.
Your system seems fine for power to do nice renderings. Laptops are often slower than desktops.
I spent a lot of time fine tuning my camera, so make sure to download my template and copy the exterior camera to your template. Then fine tune the camera if you need for your graphics card and update your template with it so you are always fine tuning your template with what works and looks the best.
Now that we are in X16, I am focusing more on using the HDRi backdrops. But as you can see above, my image backgrounds work and look great too. You will get a more realistic rendering with HDRi backdrops. But it depends on what you are looking for.
I do not use the 2D trees for shadows. The 3D trees just make a more realistic shadow.
Follow my steps in the beginning of this thread for changing some settings, like on Glass. Also on concrete, I often change the properties so I get a little reflection. Also mess with your grass. I have grass in my template that matches the backgrounds, but I have since made my grass 2 and 4 for height because I use terrain features to cut out the grass.
Position the placement of the house first as it represents the house the best. Then mess with the sun for the best looking shadows. Then place your trees to make sure they are covering the yard and onto the house a bit. I typically do not show the trees in the image, only the shadows. When CA makes some realistic looking trees I will start to put them into the foreground.
Thank you,
Steve
On 9/23/2024 at 4:55 PM, stevenyhof said:
Hi Levina,
Position the placement of the house first as it represent the house the best. Then mess with the sun for the best looking shadows. Then place your trees to make sure they are covering the yard and onto the house a bit. I typically do not show the trees in the image, only the shadows. When CA makes some realistic looking trees I will start to put them into the foreground.
Thank you,
Steve
thank you soo much !.. Ive printed all your info
  • 2 months later...
I got a nice google review this morning from a client who uploaded a black and white copy of a 3D image from the construction docs - so I spent 30 minutes copying and pasting some landscaping from another plan, crudely made my dirt landscape spaces next to the house, added a few trees for shadows, used my camera I include in this thread (from my template) and put an HDRi backdrop in. It took me 30 minutes. Could I fuss with more details, of course. As you update materials, save them as your defaults in your template. Each time you draw a new house you have things already in place within your template, including your camera(s). Drop in a backdrop, add your landscaping, bam!
  • 3 months later...
Steve, how do I download the shadow trees
Honestly, I deleted the 2D shadow trees from my personal Library. Just click on the link in the first page in this thread (I see it above). But they do not cast as nice of a shadow as 3D trees do. Follow my first steps in the beginning of this thread as I add 3D trees for shadows.
In the link is this Library. Download the file and drag it into your drawing.
thanks Steve,, BTW  (spent a lot of time fine tuning my camera, so make sure to download my template and copy the exterior camera to your template. Then fine tune the camera if you need for your graphics card and update your template with it so you are always fine tuning your template with what works and looks the best) how do I do this??
The template is in the very first post on Page 1. I highly recommend that you follow my steps exactly so you get my same results.
  • 4 weeks later...
13 minutes ago, Renerabbitt said:
Another testament to this method that Steve goes through diligently in these 6 pages of posts:
475600456_WingerPhotoManipulation.thumb.jpg.8ca91f3574d37451aa50b000abce6ed7.jpg1930028686_WingerFrontyardFinal.thumb.jpg.496b9e93983526fe1234c8616577beb3.jpg
Wow! Now that is some amazing grade work. Is the grading actually done in Chief? Or is this an image of the property before there was a house? Very impressive! I cannot think of how you did this :huh:
1 hour ago, Steve_Nyhof said:
I looked closer at your green outlines and it looks like you took pictures of various areas and put them together - maybe with photoshop? Very cleaver!
Hey thank you, this is pretty much the same method as what you post in the first post.
This is called photo manipulation/bashing, if you wanna watch one of the best in the world, hes just a young kid:
BTW this is the shot from Chief:
Maybe there are some AI apps that may be able to, but 6 months ago I messed with a number of them trying to get them to do landscaping and they often also mess with the house. You might be able to get AI to generate a background image only with some prompts that could work. I was trying to create an image out of Chief and put it into AI to generate landscaping and a background. Add an AI described background to the Chief model and I think that could work. Might have to mess with that.
3 hours ago, ACADuser said:
That photo editing was amazing.
Would AI be able to add landscape & sky to your Hill House?
So the sections highlighted in green, think of that as Clipart. I used them in order to get Ai to generate the landscape I wanted. And to Steve's point yes Ai messes with the house but you mask the house out of the Ai image. Then you can layer in more and send it back through Ai. You cna also send the house through Ai and take what's good and mask the rest back to the source image.
I have a post here somewhere about material ID masks.. That's what I'm doing with this project. Makes it easy to select an element and mask out if Ai messed with it.
Hi Rene,
What AI did you use? I know more and more AI image apps have masking so that would be the thing to use.
I use Krea, but I am doing the masking in photoshop
This is what I sent to Krea for round 1.
I used a cloud brush to cover up some problem areas. This is why I love the new ai workflow, I didnt have to do what I used to have to do which is tedious masking and bashing. I used the puppet warp tool on a straight road along with liquify to get the road markers setup. I knew that part didnt have to be perfect:
This is what I got back from Krea with low "resemblance" and high "strength"...I masked out and kept the background from this image:
Then with high "resemblance" I got this..which i Used this image as the basis for the road the front yard and the house:
which resulted in this image where those two previous images are bashed:
From there it was just fixing problems before sending it to Krea one more time and then adding a camera raw filter in photoshop where I touched pretty much every setting:
