Ceiling Height Change By Floor
ACADuser
Havent looked at plan , but doesn't the Defaults>Floor3 >Structure Tab not allow you to change the Relative Finished/Rough Ceiling height to 114" as needed?
you must be on Floor 3 to get the defaults for floor 3 to open...
Alan, it looks the ceiling height for a couple of the areas on the third floor (maybe the closets in both Bedroom 3?) were not set to "Default;" they got changed somehow. You do have that 3rd floor ceiling height set to 114" in Floor, Defauts, so making the changes seems to have resolved the issue. The third floor ceiling height is now set to 114"
Good luck!
MacDill TH-Unit A.zip
OK I was able to fix it by going into each of the 3 rooms on the 4th floor & changing the ceiling below.
Didn't work before I posted.
But I had to do it twice for one room to finally get it to work.
Thanks Joe.
