ACADuser Posted March 2, 2015 Share Posted March 2, 2015 Plan attached. Somehow the 3rd floor got changed to 120" & I need it to be 114". All my attempts have messed up the floor above. What is the solution please? Thanks MacDill TH-A.zipFetching info... Link to comment Share on other sites More sharing options...
Kbird1 Posted March 2, 2015 Share Posted March 2, 2015 Havent looked at plan , but doesn't the Defaults>Floor3 >Structure Tab not allow you to change the Relative Finished/Rough Ceiling height to 114" as needed? you must be on Floor 3 to get the defaults for floor 3 to open... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 2, 2015 Share Posted March 2, 2015 Work from the top down. Changing heights of the topmost floor effects the floor immediately below, and then changing the heights of the floor below effects the next floor down. I know this sounds stupid, but that's the way it works. Link to comment Share on other sites More sharing options...
ACADuser Posted March 2, 2015 Author Share Posted March 2, 2015 I have 3 areas on the 4th floor & do not want to change any of there current value. So how to change the 3rd floor without messing up the 4th floor? Link to comment Share on other sites More sharing options...
MickeyToo Posted March 2, 2015 Share Posted March 2, 2015 Alan, it looks the ceiling height for a couple of the areas on the third floor (maybe the closets in both Bedroom 3?) were not set to "Default;" they got changed somehow. You do have that 3rd floor ceiling height set to 114" in Floor, Defauts, so making the changes seems to have resolved the issue. The third floor ceiling height is now set to 114" Good luck! MacDill TH-Unit A.zipFetching info... Link to comment Share on other sites More sharing options...
MickeyToo Posted March 2, 2015 Share Posted March 2, 2015 Alan, It looks like those values have changed on the fourth floor. Sorry. Try following Joe's approach. Link to comment Share on other sites More sharing options...
ACADuser Posted March 2, 2015 Author Share Posted March 2, 2015 Thanks for your time. My defaults are correct but when you click on each room you get 120 for the ceiling height on floor 3. Link to comment Share on other sites More sharing options...
ACADuser Posted March 2, 2015 Author Share Posted March 2, 2015 OK I was able to fix it by going into each of the 3 rooms on the 4th floor & changing the ceiling below. Didn't work before I posted. But I had to do it twice for one room to finally get it to work. Thanks Joe. Link to comment Share on other sites More sharing options...
