Rookie65 Posted June 14 Share Posted June 14 No, because Matterport will show the windows. I just use Hover if I have to show the exterior of an existing house. It's one or the other, depending on what the job is. Or a client may do a Hover report and send it to me to get exterior dimensions for their project. Link to comment Share on other sites More sharing options...
ValleyGuy Posted June 26 Share Posted June 26 I just down loaded Chief's new As-Built app on my iPad Pro and used the LiDar scan tool. It may not be a one tool fixes everything, but it is definitely going to be a huge game changer in how I obtain as-built information. Check out the thread in the "Sales Related Questions" to see what CA's new app made in under 10 min Link to comment Share on other sites More sharing options...
SHCanada2 Posted June 26 Share Posted June 26 5 hours ago, ValleyGuy said: I just down loaded Chief's new As-Built app on my iPad Pro and used the LiDar scan tool. It may not be a one tool fixes everything, but it is definitely going to be a huge game changer in how I obtain as-built information. i've tried it a few times, and compared it to laser and to cubicasa. I do mostly basements, and it has trouble distinguishing bulkheads (sometimes thinks they are walls) and cantilevers where a 12" wall portion goes across the top. I'd be curious to hear your feedback. It uses the apple roomplan API, so I think it may be apple's limitations as opposed to CA It's nice though as it brings in windows and doors, so the elevations are less work, but based on my testing you would still need to take laser measurements for your area of interest Link to comment Share on other sites More sharing options...
ValleyGuy Posted June 26 Share Posted June 26 3 hours ago, SHCanada2 said: i've tried it a few times, and compared it to laser and to cubicasa. I do mostly basements, and it has trouble distinguishing bulkheads (sometimes thinks they are walls) and cantilevers where a 12" wall portion goes across the top. I'd be curious to hear your feedback. It uses the apple roomplan API, so I think it may be apple's limitations as opposed to CA It's nice though as it brings in windows and doors, so the elevations are less work, but based on my testing you would still need to take laser measurements for your area of interest Yes I would agree that missing or not distinguishing items such as soffits, railings, half walls etc is not CA and is fully the LiDAR's ability. In another app, I have had it pick up the kitchen island sink depression (in the correct spot) but show the island counter top overhang as a solid block to the floor. Two different apps with the same LiDAR results - I'm sure that it's an LiDAR thing. I have found that it has always been very reliable picking up walls and openings, and for that reason, I can overlook not picking up the kitchen soffits. It looks like Chief has done a great job in making the 3D model into a 2D plan view, as well as removing the clutter and furniture. I just loaded it this morning, shot the house with it, turned on the interior dimensions and posted the results. Literally no edits just to see the accuracy. If you look at the comparison of the two (in the other thread under Sales Related Questions) you will see that the LiDAR CA generated dimensions are very close to the actual laser measured ones that I put in yellow earlier in the thread. This app probably won't instil enough confidence to just scan and walk away for me, as I'm a 'measure twice' kind of drafter, but it sure will remove any drawing on site, plus be a much faster way to adjust the walls to the correct dimensions. I think that Chief did a great job to make it 'Draft Person Friendly' so far. I'll sit down with it soon to learn what it really has under the hood for options, hopefully there are some good nuggets yet to find. Link to comment Share on other sites More sharing options...
SHCanada2 Posted June 27 Share Posted June 27 (edited) 20 hours ago, ValleyGuy said: sure will remove any drawing on site, plus be a much faster way to adjust the walls to the correct dimensions I'm curious as to how this will be done. today when I take dimensions, I will need to correct interior dimensions that i took to reflect the building outer walls. In this respect, I dont want to accidentally adjust a wall in the app and move the exterior wall(the CA app gives you the ability to put in reference measurements, but that is static. You seem to be saying you will correct actual wall dimensions in the app). In CA you can easily see this and control it. Running around with a tablet and adjusting, I would think would be prone to errors. I think in my ideal workflow, I would go scan, download to CA, print it out and go measure each room, and then reconcile in CA. It's like ordering food at a restaurant, it used to be the server would write down the order. Now they bring a tablet and are constantly asking sorry what did you say you wanted with that...because they have to sit there navigating the menus and drop downs on the tablet. Maybe I'm wrong and you can get the efficiency in the tablet by fixing the walls in the app. It was an excercise in frustration when I used to try and do it with the measureon app. So much that I gave up and now just draw the plan in CA onsite on my laptop (after sketching out the layout on paper). I asked Ca to see if they could provide us a point cloud as well. If they did then we could reconcile where the app made an incorrect decision(in aligning walls). So yeah I'm curious if you will find it to be more efficient to use the app, take some control measurements, and then download to CA and finish fixing the plan. Or if you will fix everything in the app by taking more manual dimensions and moving the walls around in the app and curious, where are you noting bulkhead AFF, and dimensions? Edited June 27 by SHCanada2 Link to comment Share on other sites More sharing options...
ValleyGuy Posted June 28 Share Posted June 28 4 hours ago, SHCanada2 said: I'm curious as to how this will be done. today when I take dimensions, I will need to correct interior dimensions that i took to reflect the building outer walls. In this respect, I dont want to accidentally adjust a wall in the app and move the exterior wall(the CA app gives you the ability to put in reference measurements, but that is static. You seem to be saying you will correct actual wall dimensions in the app). In CA you can easily see this and control it. Running around with a tablet and adjusting, I would think would be prone to errors. I think in my ideal workflow, I would go scan, download to CA, print it out and go measure each room, and then reconcile in CA. It's like ordering food at a restaurant, it used to be the server would write down the order. Now they bring a tablet and are constantly asking sorry what did you say you wanted with that...because they have to sit there navigating the menus and drop downs on the tablet. Maybe I'm wrong and you can get the efficiency in the tablet by fixing the walls in the app. It was an excercise in frustration when I used to try and do it with the measureon app. So much that I gave up and now just draw the plan in CA onsite on my laptop (after sketching out the layout on paper). I asked Ca to see if they could provide us a point cloud as well. If they did then we could reconcile where the app made an incorrect decision(in aligning walls). So yeah I'm curious if you will find it to be more efficient to use the app, take some control measurements, and then download to CA and finish fixing the plan. Or if you will fix everything in the app by taking more manual dimensions and moving the walls around in the app and curious, where are you noting bulkhead AFF, and dimensions? So playing around on the CA As-Built app here is what I found. The walls seem to be easily moved due to the controls that Chief has installed. For example, a vertical wall can only move left or right on the page. A horizontal wall can only go up or down on the page. I didn't test any diagonal walls, but from the Q&A webinar answer, they will respond in a similar fashion. Curved walls... I wouldn't hold my breath if I was you. Once a wall is selected, it will have dimensions already attached, or temporary ones will appear. Only the highlighted wall will move (no directional pop up like in Premier). So you either lengthen or shorten the attached dimension, the dimension is anchored and the highlighted wall is what will move. I didn't find any waitress with an iPad issues at all. This part of the app seems to be sound. Again, this app has some bugs with drawing or moving a free end (non attached) wall which I'm sure they are working on. Once they get that little glitch ironed out, I'm pretty sure that nudging walls will be done right on the app on site without worry. A nice touch is how Chief has the windows and doors set up. The individual item has an info panel to manually input over ride values (or easily double check values). And the wall containing the opening also pops up the dimensions from both edges to the next perpendicular wall so you can adjust on the fly. Another thing that I found; because I don't like to use decimal points, the app dimensions will round up/down to the inch. And I'm ok with that. Most everything that I do has varying degrees of accuracy depending on the situation. And sometimes when measuring a 250 year old house, accuracy is a luxury beyond reach... Here's what I hope to accomplish... As I chose a desk top and iPad over a laptop, I am trying to use what I do have on-site to not make multiple trips between the office and the site. Sometimes multiple customer meetings are hard to schedule, so I want to make the most of the time that I'm there. I find that I spend a lot less time getting decisions made by sketching in front of the customer. Way faster than using Chief and preparing a layout to email. I hope to also have time to sketch ideas on-site. I expect to measure the house to some degree. Again, some instances need very high accuracy, and others not so much, I may only rely on the LiDAR results for those specific areas. I also expect to have to make notes and draw in items that current tech isn't capable of yet. I should have stated above that this CA app will remove a lot of what I currently draw on-site. Here's the logistics that I'm thinking of... LiDAR isn't the full package yet no matter how good Chief is, there are things that it just doesn't do yet. Likewise, I don't think the CA As-Built app is a full one stop shop yet either (it was only just released!). So I plan to use the Morpholio Trace app in conjunction with CA's app. I believe it was designed with the iPad to be it's main hardware too so it works well on the iPad. I'm thinking that this package will serve as my on-site CA As-Built back up, mark up, red line, customer detail sketch book, and video camera - all in one. - CA Back-Up: I'll just screen shot the initial CA LiDAR dimensioned plan and keep it in photos. Just in case I need to compare any suspected unauthorized wall movements. - Red Line: More like CA app lidar dimension discrepancy check. Let's be honest, we have to feel comfortable that the LiDAR measurements are close enough to reality. For this, I plan to input the saved CA screen shot photo in to Morpholio Trace as the base layer. Then I can lay a trace layer over top and start confirming the room measurements. Circle in red and 'pencil' in correct room measurements as needed. - Split screen the iPad: CA app / Morpholio Trace app. Adjust the CA app walls using the M.Trace red lined dimension values. - Now confirm window / door measurements if wanted, placement, and swing direction in the CA plan. (Door types that are different than Hinged can be drawn in M.Trace.) - Screen Shot the newly modified CA floor plan again. - Reload the new screen shot photo into M.Trace - Mark Up: in the new reloaded M. Trace app. Place layers of trace paper down to draw in the things that LiDAR doesn't pick up (soffits, stair wells, railings, beams, ...), the items CA decided to remove from the 2D plan (cabinets, built-ins, appliances, plumbing, fireplace,...), and all the other items of interest: notes, the types of doors, configuration of windows, floor patterns, patios, exterior steps, electrical, mechanicals, ... So now there should be a very accurately dimensioned floor plan in the CA app with walls and openings, and a very sporty looking floor plan of the as-built complete with all the missing bits in the M.Trace app. And of course, take some pics and a video or two. Make some mark ups on the pictures in the iPad's Freeform app if needed for things like the roofline, porches, decks,... Now the remodel / addition fun can start with the client. In the M.Trace app, put down more trace paper layers for all the ideas and options. Even draw in upper and lower floor levels or doodle new roofline / dormer options. By the end, I hope to measure only once, and have it all contained on the iPad, done on-site during the one visit - depending on how big the project is of course. Link to comment Share on other sites More sharing options...
SHCanada2 Posted June 28 Share Posted June 28 1 hour ago, ValleyGuy said: Then I can lay a trace layer over top and start confirming the room measurements. Circle in red and 'pencil' in correct room measurements as needed. - Split screen the iPad: CA app / Morpholio Trace app. Adjust the CA app walls using the M.Trace red lined dimension values. hmm, i dont get this part. why not just adjust the walls in the CA app directly, vs sounds like you are still going to type in the dimensions for each room in the trace app,, then adjust the walls in CA? Are you doing it in the trace app so you have a permanent, unaltered record? (this is why I do it on paper today...walls can't move on paper) Link to comment Share on other sites More sharing options...
ValleyGuy Posted June 28 Share Posted June 28 4 hours ago, SHCanada2 said: hmm, i dont get this part. why not just adjust the walls in the CA app directly, vs sounds like you are still going to type in the dimensions for each room in the trace app,, then adjust the walls in CA? Are you doing it in the trace app so you have a permanent, unaltered record? (this is why I do it on paper today...walls can't move on paper) Yes, this my reconcile part. I'm not 100% confident enough to not have a back-up that 'can't move'. I'm also not yet convinced that LiDAR can fully flush out the always found different interior wall thicknesses, slight wall jogs, furred portions of walls, and boxed in dead spots that derail the exterior measurements. Plus, some closets are just not LiDAR scan possible. The CA app will also never be able to do "everything" either, it isn't meant to. I'm thinking that 'most' of the floor plan can be drawn and reconciled on-site on the iPad at best. Fine detail information 'written down' will probably always be a constant, to be taken back to the office where more time and/or a more robust program await. On a side note... The trace app is quick just using the pencil to write rather than type text boxes. And the portability of a cross body strap on the iPad (encased in a rubber 'kid proof' w/ pencil holder) allows both hands free to measure. This part should go quickly. I'll probably also grab the door and window info while I'm in the room too. I'm thinking that sitting down to move all the necessary walls and confirm the openings in the CA app will be faster doing it all at once on a table top than holding the iPad room to room. Link to comment Share on other sites More sharing options...
SHCanada2 Posted June 28 Share Posted June 28 7 hours ago, ValleyGuy said: I'll probably also grab the door and window info while I'm in the room too You can see, while scanning, in the CA app when it outlines the windows. It's one thing I am considering not measuring manually and just using the CA app's determined size and location..at least for the rooms not being renoed. Link to comment Share on other sites More sharing options...
ValleyGuy Posted June 29 Share Posted June 29 15 hours ago, SHCanada2 said: You can see, while scanning, in the CA app when it outlines the windows. It's one thing I am considering not measuring manually and just using the CA app's determined size and location..at least for the rooms not being renoed. I agree with just relying on LiDAR for the rooms not being reno'd. So far the opening size and location accuracy from the scan has been more than acceptable for this purpose, at least for the rooms that aren't on a one or two step height difference. Those ones are just off in the elevation height. Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 16 Share Posted September 16 (edited) On 2/21/2026 at 3:06 PM, DRAWZILLA said: check out a new release of Moasure LX1 coming out soon I got a notice today for option to buy for a $100 discount on $1500, not exactly a lot. They do have the doc up and some videos on how to use. They also specify accuracy as +-1 inch ...per room it looks like. not great once you aggregate it all together. It also looks like it creates the floor plan as you go, which means it has the same type of logic as the apple room API. i.e it has to choose what walls to change the measured value on in order to close the room. It has an odd room transition. They recommend to,, hit the add room button on the app, then put the LX on the jamb to measure the wall thickness. ...and how exactly would that work? the casing is typically almost flush, which would mean, if it included the casing, they would calculate the wall to be another 1.5" thick. There must be something going on to mitigate this I also never saw in the video where they size a window that is flush with the wall. I would think maybe you just put it on either side of the window. ...and it does not show measuring a closet with a bunch on clothes in it. The one video I saw the guy says if it cannot get a laser reading it uses the gyro. it would be interesting to see a real life scenario with a third party reviewer. I looked around but have not seen one yet Edited September 16 by SHCanada2 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 16 Share Posted September 16 11 hours ago, SHCanada2 said: I got a notice today for option to buy for a $100 discount on $1500, not exactly a lot. They do have the doc up and some videos on how to use. They also specify accuracy as +-1 inch ...per room it looks like. not great once you aggregate it all together. It also looks like it creates the floor plan as you go, which means it has the same type of logic as the apple room API. i.e it has to choose what walls to change the measured value on in order to close the room. It has an odd room transition. They recommend to,, hit the add room button on the app, then put the LX on the jamb to measure the wall thickness. ...and how exactly would that work? the casing is typically almost flush, which would mean, if it included the casing, they would calculate the wall to be another 1.5" thick. There must be something going on to mitigate this I also never saw in the video where they size a window that is flush with the wall. I would think maybe you just put it on either side of the window. ...and it does not show measuring a closet with a bunch on clothes in it. The one video I saw the guy says if it cannot get a laser reading it uses the gyro. it would be interesting to see a real life scenario with a third party reviewer. I looked around but have not seen one yet Yep, I purchased one, shipping Friday. Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 18 Share Posted September 18 (edited) On 9/16/2026 at 9:14 AM, DRAWZILLA said: Yep, I purchased one, shipping Friday. the offer was good for the rest of the year. Given I could not find any feedback, well that and its like $2k CAD, I decided to wait to see what people reviews are...and real people in the industry, not just some reviewer guy. So hopefully you will provide some valuable feedback. My biggest concern with all of these things that "make a floor plan" is they never seem to tell you what they adjusted to make it work. Given their stated accuracy is +- 1 inch, I dont want a bathroom shrinking an inch when they put it altogether. think most of these types of program make the walls thicker for the most part. but still, why not give me the raw measurements as well wo i can decide. I guarantee you a bathtub cant shrink by an inch Edited September 18 by SHCanada2 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 18 Share Posted September 18 10 hours ago, SHCanada2 said: the offer was good for the rest of the year. Given I could not find any feedback, well that and its like $2k CAD, I decided to wait to see what people reviews are...and real people in the industry, not just some reviewer guy. So hopefully you will provide some valuable feedback. My biggest concern with all of these things that "make a floor plan" is they never seem to tell you what they adjusted to make it work. Given their stated accuracy is +- 1 inch, I dont want a bathroom shrinking an inch when they put it altogether. think most of these types of program make the walls thicker for the most part. but still, why not give me the raw measurements as well wo i can decide. I guarantee you a bathtub cant shrink by an inch yes, I realize there will be some fix up, and I don't mind it. I usually have to fix everything anyway with regular laser measurements to some degree. What I like about this is it will capture wall thickness which is something you can never get with hand measurements and screws up you measurements. I guess shortly I'll find out. BTW you can buy one now, but you have to be on a wait list. Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 18 Share Posted September 18 6 hours ago, DRAWZILLA said: yes, I realize there will be some fix up, and I don't mind it. I usually have to fix everything anyway with regular laser measurements to some degree. What I like about this is it will capture wall thickness which is something you can never get with hand measurements and screws up you measurements. I guess shortly I'll find out. BTW you can buy one now, but you have to be on a wait list. they have a demo and Q&A next Thursday. I will ask the questions if i get the chance Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 21 Share Posted September 21 get mine today, I'll test for a couple days then let you know. Link to comment Share on other sites More sharing options...
SHCanada2 Posted October 17 Share Posted October 17 (edited) On 9/21/2026 at 9:28 AM, DRAWZILLA said: I'll test for a couple days then let you know. They put out a demo video. But when they scan the second room and are measuring the last wall (which is a common wall to the first room), it draws that wall about 1 foot into the original room(erroneously) So I assume their measurements from the second room do not "Add up", and now either the program adjusted the length of the walls, or the user did and it just didnt show on the video.The biggest issue I have with corrections, is "which wall did they change, and how do they know it is the right one to change". My guess by watching this video is they just corrected the last wall scanned before the common wall, by the amount the common wall is out by. i.e. because it was out by a foot, they shortened the wall measured perpendicular to it by a foot HAve you seen this behaviour so far in your testing? Have you verified it against a laser? I'm in decision paralysis. Now I'm looking at SLAM scanners, about 6K, but you get a point cloud supposedly good to 0.5 inch, and you can walk and scan and be done in like 5 minutes. ...and it does exteriors. no subscriptions, one time HW cost only. looks like it picks up everything good enough to dimension windows, doors are tougher(almost have to measure the casing onsite and then dimension casing to casing) Edited October 17 by SHCanada2 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 17 Share Posted October 17 (edited) 10 hours ago, SHCanada2 said: They put out a demo video. But when they scan the second room and are measuring the last wall (which is a common wall to the first room), it draws that wall about 1 foot into the original room(erroneously) So I assume their measurements from the second room do not "Add up", and now either the program adjusted the length of the walls, or the user did and it just didnt show on the video.The biggest issue I have with corrections, is "which wall did they change, and how do they know it is the right one to change". My guess by watching this video is they just corrected the last wall scanned before the common wall, by the amount the common wall is out by. i.e. because it was out by a foot, they shortened the wall measured perpendicular to it by a foot HAve you seen this behaviour so far in your testing? Have you verified it against a laser? I'm in decision paralysis. Now I'm looking at SLAM scanners, about 6K, but you get a point cloud supposedly good to 0.5 inch, and you can walk and scan and be done in like 5 minutes. ...and it does exteriors. no subscriptions, one time HW cost only. looks like it picks up everything good enough to dimension windows, doors are tougher(almost have to measure the casing onsite and then dimension casing to casing) It did happen to me but as I got better doing it doesn't happen anymore. It's almost every time a user error in measuring. If you forget to place your last point or another point in that room, on the same wall, it could give you that extra wall. You cannot delete that wall so just delete and re-measure that room. you can always delete and re-measure the last room you did. Edited October 17 by DRAWZILLA Link to comment Share on other sites More sharing options...
SHCanada2 Posted Sunday at 12:35 AM Share Posted Sunday at 12:35 AM 9 hours ago, DRAWZILLA said: It did happen to me but as I got better doing it doesn't happen anymore. It's almost every time a user error in measuring. If you forget to place your last point or another point in that room, on the same wall, it could give you that extra wall. You cannot delete that wall so just delete and re-measure that room. you can always delete and re-measure the last room you did. have you checked their dims against a laser...how close Link to comment Share on other sites More sharing options...
DRAWZILLA Posted Sunday at 03:16 PM Share Posted Sunday at 03:16 PM dims were same as laser, I was suprised. Link to comment Share on other sites More sharing options...
SHCanada2 Posted Sunday at 05:10 PM Share Posted Sunday at 05:10 PM (edited) 2 hours ago, DRAWZILLA said: dims were same as laser, I was suprised. that is surprising. even lower end commerical grade scanners are only accurate to +-0.75 inch. higher end to 1/8" I think I have convinced myself to go the SLAM (mobile) scanner route, just for the fact that if I missed something, like dropped beam, or stairs proud of a wall, I can go back to the point cloud and measure. Plus, they all seem to have actual cameras on them, so you also get a 3d model which actually look like the interior (similar to matterport). and they can do exterior so I could definitively know building height for instance. one time HW cost, no subscriptions, you own the data, can measure everything from the desktop. ...or at least I've convinced myself. most scanner vendor software can give you a floorplan (or alternatively trace the walls) The only question left is which one to buy. I'm currently in price creep mode Edited Sunday at 05:17 PM by SHCanada2 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted Sunday at 08:22 PM Share Posted Sunday at 08:22 PM 3 hours ago, SHCanada2 said: that is surprising. even lower end commerical grade scanners are only accurate to +-0.75 inch. higher end to 1/8" I think I have convinced myself to go the SLAM (mobile) scanner route, just for the fact that if I missed something, like dropped beam, or stairs proud of a wall, I can go back to the point cloud and measure. Plus, they all seem to have actual cameras on them, so you also get a 3d model which actually look like the interior (similar to matterport). and they can do exterior so I could definitively know building height for instance. one time HW cost, no subscriptions, you own the data, can measure everything from the desktop. ...or at least I've convinced myself. most scanner vendor software can give you a floorplan (or alternatively trace the walls) The only question left is which one to buy. I'm currently in price creep mode I also take a couple hundred pictures along with measuring. Link to comment Share on other sites More sharing options...
SHCanada2 Posted Sunday at 11:12 PM Share Posted Sunday at 11:12 PM 2 hours ago, DRAWZILLA said: I also take a couple hundred pictures along with measuring. interesting thats a lot, today I take a video, but that even misses things, and well I cannot measure from it. Curious, have you looked at handheld scanners (no tripod to setup) which produce both point clouds and 3DGS, and/or 3DGS only cameras (which are also measurable). And if so, what got you to the LX1 vs a scanner or a 3DGS camera? example 3DGS XGRIDS LCC the measurement is nice as it shows you how far off the axis you are Link to comment Share on other sites More sharing options...
DRAWZILLA Posted Monday at 03:33 PM Share Posted Monday at 03:33 PM 16 hours ago, SHCanada2 said: interesting thats a lot, today I take a video, but that even misses things, and well I cannot measure from it. Curious, have you looked at handheld scanners (no tripod to setup) which produce both point clouds and 3DGS, and/or 3DGS only cameras (which are also measurable). And if so, what got you to the LX1 vs a scanner or a 3DGS camera? example 3DGS XGRIDS LCC the measurement is nice as it shows you how far off the axis you are I have other people measure for me so the lx1 seems to help with them laying out the floor, rather than hand drawing, sometimes I just can't read their writing or figure out what they were trying to draw by hand, and this solves all those problems. When I get the layout, It's ready to go, I can trace it or use cad to walls to start. i can get the file before they even leave the project site. I can also have the floor already in chief before they even get back from measuring. Big time saver. we still do the site measurements by hand. I thinking of also buying the Moasure 2 pro for that. Link to comment Share on other sites More sharing options...
SHCanada2 Posted Monday at 08:17 PM Share Posted Monday at 08:17 PM 4 hours ago, DRAWZILLA said: Big time saver. we still do the site measurements by hand. I thinking of also buying the Moasure 2 pro for that. interesting, what do you measure for the site plan? For me, I have no idea where the property lines are when I am onsite, so there is not a lot to measure per se. I just take pictures of the building in order to try and create representative elevations. the one thing I might measure is the main floor to grade, front and back to get the terrain accurate for the elevations. Occasionally I will take a laser and measure elevation changes between certain points if for instance they are putting in a new garage on a sloped terrain Link to comment Share on other sites More sharing options...
