Cadwork22 Posted February 28, 2024 Share Posted February 28, 2024 I need to create a closet under the stairs, I was able to do this with the L Shaped but having trouble with the U shaped. I attached the stair image. Thanks, as always. Link to comment Share on other sites More sharing options...
RL-inc Posted February 28, 2024 Share Posted February 28, 2024 Use walls to create room under the stairs and set the ceiling heigh to match bottom of landing framing? Link to comment Share on other sites More sharing options...
Solution DBCooper Posted February 28, 2024 Solution Share Posted February 28, 2024 This is how I like to draw them (and I don't think you need to mess around with ceiling heights). Link to comment Share on other sites More sharing options...
Gawdzira Posted February 29, 2024 Share Posted February 29, 2024 Sometimes you will need to cheat the wall location slightly under the stair stringer so the wall does not continue up past the stringer depending on your desired design. Link to comment Share on other sites More sharing options...
Cadwork22 Posted February 29, 2024 Author Share Posted February 29, 2024 Thanks, finally got it figured out. Link to comment Share on other sites More sharing options...
