Brian_Wisner_PE Posted February 21, 2024 Share Posted February 21, 2024 I am trying to draw a deck along a wall that is angled at 45-degrees. For some reason the program will draw decks everywhere else other than along the 45-degree wall. Is there a special setting I should be using somewhere? In the refence photo I have drawn decks along the other walls and a free standing deck to show its not a graphical issue. Any help would be greatly appreciated! This is in Cheif Architect Premier X15. Link to comment Share on other sites More sharing options...
GeneDavis Posted February 21, 2024 Share Posted February 21, 2024 Open for spec one of the OK walls. Take a screencap of the wall's type. In the structure tab, take a screencap. See my examples. Now do the same for the 45 wall. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 21, 2024 Share Posted February 21, 2024 2 hours ago, Brian_Wisner_PE said: In the refence photo I have drawn decks along the other walls and a free standing deck to show its not a graphical issue. Any help would be greatly appreciated! Not sure I have seen that happen before but , in plan view click on the Room and open it, and goto to the Deck tab and make sure "Retain Framing" is not selected as if it was engaged with no framing built it won't rebuilt it now. Link to comment Share on other sites More sharing options...
ArmanChahal Posted February 21, 2024 Share Posted February 21, 2024 I tried to recreate the situation. It just worked. Can you share the plan? Also make sure all the deck walls are the attached to the main house. Link to comment Share on other sites More sharing options...
NHwoodworks Posted March 19, 2024 Share Posted March 19, 2024 Any Update on this? I'm having the same issue, however it's on a strait exterior wall. I can place another deck right next to it without issue. Problem started when resizing room. Link to comment Share on other sites More sharing options...
DBCooper Posted March 19, 2024 Share Posted March 19, 2024 Post the plan and someone can probably figure it out. Link to comment Share on other sites More sharing options...
