EllaFioletova Posted February 19, 2024 Share Posted February 19, 2024 How to set up different layer for connect electrical? i need to show wich outlets stay on one wire, wich on other , and separate this information from ceiling light connection. Link to comment Share on other sites More sharing options...
DBCooper Posted February 20, 2024 Share Posted February 20, 2024 You should be able to open the dialog for the electrical connection and assign it to any layer you want. Link to comment Share on other sites More sharing options...
GeneDavis Posted February 20, 2024 Share Posted February 20, 2024 Now is a good time to learn to make new layers for your specific needs in controlling visibility of objects. Click on "New" and type in your new layer's name. Link to comment Share on other sites More sharing options...
EllaFioletova Posted February 20, 2024 Author Share Posted February 20, 2024 I created separate layers for different types of connections. My question was how to assign the specific layer I need as the default for connections. I handle layers for the actual electrical elements easily in the settings. Link to comment Share on other sites More sharing options...
EllaFioletova Posted February 20, 2024 Author Share Posted February 20, 2024 7 hours ago, DBCooper said: You should be able to open the dialog for the electrical connection and assign it to any layer you want. I can't found this setting ((( Link to comment Share on other sites More sharing options...
DBCooper Posted February 20, 2024 Share Posted February 20, 2024 Select the electrical connection. Use the "open object" tool. In the dialog, go to the "line style" page. You should be able to change the layer from the default "electrical connections" to whatever you want. If you don't have the open button or the line style panel, then my only guess is that you are not using X15 Premier. Link to comment Share on other sites More sharing options...
TeaTime Posted February 20, 2024 Share Posted February 20, 2024 16 minutes ago, DBCooper said: Select the electrical connection. Use the "open object" tool. In the dialog, go to the "line style" page. @EllaFioletova As you can probably assume, this is a manual process. You have to draw out all your connections, select the ones you want to set to a different layer, open them and manually change the layer they're on. Super frustrating that there's no defaults for the electrical connections. Sure would make this type of thing loads easier. 1 Link to comment Share on other sites More sharing options...
EllaFioletova Posted February 21, 2024 Author Share Posted February 21, 2024 10 hours ago, DBCooper said: Select the electrical connection. Use the "open object" tool. In the dialog, go to the "line style" page. You should be able to change the layer from the default "electrical connections" to whatever you want. If you don't have the open button or the line style panel, then my only guess is that you are not using X15 Premier. thanks for answer , i know how to do it. But my question was about settings for this ))), i just curious if it possible or not Link to comment Share on other sites More sharing options...
