cbucks Posted February 17, 2024 Share Posted February 17, 2024 How do you convert a foundation wall to a terrain retaining wall? Link to comment Share on other sites More sharing options...
rgardner Posted February 17, 2024 Share Posted February 17, 2024 1 hour ago, cbucks said: How do you convert a foundation wall to a terrain retaining wall? Place a terrain break line in the middle of that wall and elevation lines on each side, then shape it manually in a cross section view as you want. 1 Link to comment Share on other sites More sharing options...
Mark3D Posted February 17, 2024 Share Posted February 17, 2024 Also apply this setting show in image. 1 Link to comment Share on other sites More sharing options...
cbucks Posted February 17, 2024 Author Share Posted February 17, 2024 When I checked the box Terrain Retaining Wall on the foundation wall I get the error "The terrain interpolator is ignoring terrain breaks and retaining walls due to complexity of this calculation" If I uncheck terrain retaining wall I don't get the error but my 3d is pretty messed up as you can see I am getting weird spikes Link to comment Share on other sites More sharing options...
Mark3D Posted February 17, 2024 Share Posted February 17, 2024 Upload your file and I or others should be able to tell what is wrong Link to comment Share on other sites More sharing options...
dshall Posted February 17, 2024 Share Posted February 17, 2024 I would do as RGARDNER suggests, do tot check box for retaining wall. 2 Link to comment Share on other sites More sharing options...
rgardner Posted February 19, 2024 Share Posted February 19, 2024 On 2/16/2024 at 11:46 PM, Mark3D said: Also apply this setting show in image. I actually disagree with this statement. That will cut the wall to the profile of the terrain. I would personally do it how they would build it IRL and manually cut the top edge and step it down where needed. Link to comment Share on other sites More sharing options...
