garage doors
decorators3
I've attached a front image of the workshop
Here is the problem.  There are two  garages doors with  different heights and widths .
When I try to install a garage door with windows in the larger door I get two sets of windows.  How do I get just the windows across the top with out showing up in the middle   If I use right side windows from top to bottom they are fine
The  garage door is 144 " wide x 192" in height.
This is in residential template but same thing occurs if I use a commercial template
Any suggestions thanks
ok  I only want  window lites   in the 8 top portion . it appears as two doors with windows   when I use the door from the manufacturers.   guessing it only registers to standard garge door heights.
How to make my own door symbol .. I will check out the help videos
Thank you I appreciate you replying to me
Cheers
Levina
Solver (Eric) made a two or three part garage door video that you may be able to still find on his youtube channel that is very informative and should meet your needs.
