Jonathan3891 Posted February 9, 2024 Share Posted February 9, 2024 How do I go about editing this garage stem wall width so it's as wide as the sill plate? I have the sill plate width set in the foundation defaults. Link to comment Share on other sites More sharing options...
imodel Posted February 9, 2024 Share Posted February 9, 2024 You need to post the plan. Your section does not match your default setting. Link to comment Share on other sites More sharing options...
Jonathan3891 Posted February 9, 2024 Author Share Posted February 9, 2024 I've rebuilt the foundation several times trying to fix this issue. NDS Plan.layout Link to comment Share on other sites More sharing options...
Doug_N Posted February 9, 2024 Share Posted February 9, 2024 In regards to what Eric said, the layout file does not contain a copy of the plan file, just a link to it that is a relative link. The link only works while on your system. When posting files, the minimum post for CA is the plan file. Link to comment Share on other sites More sharing options...
Jonathan3891 Posted February 9, 2024 Author Share Posted February 9, 2024 I'm sorry about that! NDS Plan.zip Link to comment Share on other sites More sharing options...
Solution SNestor Posted February 9, 2024 Solution Share Posted February 9, 2024 On the foundation level (Level 0) select the three foundation walls at the Garage. Change the wall type to a 10" (or larger if you want) conc. stem wall. Just make a copy of the current stem wall...change the name and the width. Link to comment Share on other sites More sharing options...
Doug_N Posted February 9, 2024 Share Posted February 9, 2024 Ok so your problem with the garage curb wall is that the 6" width starts at the exterior edge of the slab. Take away the brick ledge and you are left with just a sliver of curb to support the framework. Link to comment Share on other sites More sharing options...
Doug_N Posted February 9, 2024 Share Posted February 9, 2024 Steve beat me to it, but my post has nice pictures! 2 Link to comment Share on other sites More sharing options...
