GrizzlyBear Posted January 29, 2024 Share Posted January 29, 2024 I have an interior wall elevation (Tile, Bath 1) in my Cross Sections folder that I need to work on that uses a custom layer set (Tile and Backsplash Layer Set). I can't seem to get the shower pan to show itself not matter what I do. -The layer that the shower pan is on is the 'Fixtures, Interior' layer and I have verified that the box for that layer is checked. -Tried displaying ALL layers. -I have tried pulling my elevation camera all the way through the opposing wall. -Even tried opening and closing shower door. -And finally of course opening and closing the program. Bouknight_rev2.plan.zip Thx for any help! Link to comment Share on other sites More sharing options...
Solution Renerabbitt Posted January 29, 2024 Solution Share Posted January 29, 2024 29 minutes ago, GrizzlyBear said: I have an interior wall elevation (Tile, Bath 1) in my Cross Sections folder that I need to work on that uses a custom layer set (Tile and Backsplash Layer Set). I can't seem to get the shower pan to show itself not matter what I do. -The layer that the shower pan is on is the 'Fixtures, Interior' layer and I have verified that the box for that layer is checked. -Tried displaying ALL layers. -I have tried pulling my elevation camera all the way through the opposing wall. -Even tried opening and closing shower door. -And finally of course opening and closing the program. Bouknight_rev2.plan.zip 3.06 MB · 2 downloads Thx for any help! without opening your plan I am guessing that you are using a wall elevation camera, which is clipped to a room. you need to edit your active view and uncheck clip to room and then likely adjust a back clip and side clip parameters Link to comment Share on other sites More sharing options...
robdyck Posted January 29, 2024 Share Posted January 29, 2024 Edit the view by unchecking "Clip to Room" Link to comment Share on other sites More sharing options...
SNestor Posted January 29, 2024 Share Posted January 29, 2024 The shower base is showing...it just appears like a baseboard. Just a suggestion...the glass shower wall should be centered on the width of the base curb. Then raise the door 5" or so....to the top of the shower base. Link to comment Share on other sites More sharing options...
GrizzlyBear Posted January 29, 2024 Author Share Posted January 29, 2024 Rene and Rob Thx. That was it obviously, and I have no idea how I would have figured that one out. And Thx for the tip with the door Steve! 1 Link to comment Share on other sites More sharing options...
robdyck Posted January 29, 2024 Share Posted January 29, 2024 14 minutes ago, GrizzlyBear said: and I have no idea how I would have figured that one out. I'll explain how I learned this tool's function. Single click the Wall Elevation tool and then press F1. From Help: The Wall Elevation tool creates an interior elevation of a single wall defining the room that the camera is drawn in. It creates a 2D projection of that wall and the objects located between that wall and its Cross Section Line; This statement from Help should guide us to understand the difference between a Wall Elevation and the back clipping function of other camera views. Further reading in the Help file is even more descriptive: With the camera dialog open, press help and review that page, specifically the Scene Clipping portion. This should explain why a wall elevation isn't showing anything beyond the glass wall (the base is in a different room). Best of luck! 1 Link to comment Share on other sites More sharing options...
SNestor Posted January 29, 2024 Share Posted January 29, 2024 Just FYI. I used a back-clipped camera…not the wall elevation camera Link to comment Share on other sites More sharing options...
