SHCanada2 Posted January 26, 2024 Share Posted January 26, 2024 I dont think most people use RTRT cameras on layouts, but if there someone that does, or if someone knows how to " fix" this it would be appreciated. The CA save to PDF is creating a washout look compared to what I see in camera or the camera on layout, for cameras with bright sunlight. It can be seen most in the camera on the lower right: Layout: PDF (600DPI @24x36) to scale camera: thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 26, 2024 Share Posted January 26, 2024 You need to turn down the "Sunlight" using RTRT. Photo realism doesn't just happen if one is a "good buy", rather it is resident completely your responsibility to tweak a rendering by adjusting its settings (material and lighting) to obtain an acceptable result. Unfortunately it is an Art as opposed to a Science, you learn via study followed by practice-trial and error. DJP 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 26, 2024 Author Share Posted January 26, 2024 9 minutes ago, DavidJPotter said: You need to turn down the "Sunlight" using RTRT. Photo realism doesn't just happen if one is a "good buy" I'm not sure I understand. If the camera is how I like it, then I need to reduce the sunlight so it is darker than I would like, so that when it prints to pdf, it is brighter than the camera? This would seem to be a painful process Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 26, 2024 Author Share Posted January 26, 2024 the irony is if I print the image from the plan file it prints it correctly: Link to comment Share on other sites More sharing options...
Gawdzira Posted January 26, 2024 Share Posted January 26, 2024 When I send to layout, I send as an image. Are you sending live views? Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 26, 2024 Author Share Posted January 26, 2024 5 minutes ago, Gawdzira said: Are you sending live views? yes Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 26, 2024 Author Share Posted January 26, 2024 I found the problem, or perhaps, weird behaviour. If the camera is actually open when I print the layout to pdf, it prints correctly. If the camera is not open, it gets the washed out look it does happen if I reduce the sun as well, just much less obvious, I reduced the sun from 2500 to 500, much better Link to comment Share on other sites More sharing options...
