Missing Saved Elevation View
ChiefDesign2023
You can right-click on the camera name in the browser and use "open view".
If the view opens, but you don't see anything, it might be because the model is off the screen.  Try using "fill window" (F6) to see if it comes back.
If you still can't see anything, then it might be because you changed the layer set to one that isn't showing anything.
If it isn't one of these, then you should probably post the plan.
  • Like 2
