HumbleChief Posted January 17, 2024 Share Posted January 17, 2024 I've got some text stacked in my story pole dims and can't figure out how to make them more readable. Thanks Link to comment Share on other sites More sharing options...
HumbleChief Posted January 17, 2024 Author Share Posted January 17, 2024 Weird. My template plan seems to separate them fine Link to comment Share on other sites More sharing options...
HumbleChief Posted January 17, 2024 Author Share Posted January 17, 2024 I have 2 buildings and the story pole seems to want to pull the correct data from one larger existing home (that will not be changed and is not part of the submittal) and not so great off the separate smaller building that is in the submittal scope of work. I'd like to pull the story pole info off the smaller building but it's not cooperating. https://www.dropbox.com/scl/fi/ievtup48zv0zv6qkgi5r0/STORY-POLE-PLAN.plan?rlkey=xk4cpkl3lvu4079tr45czggux&dl=0 Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 17, 2024 Share Posted January 17, 2024 4 hours ago, HumbleChief said: I have to manually move them to look like this 1 Link to comment Share on other sites More sharing options...
rgardner Posted January 17, 2024 Share Posted January 17, 2024 5 hours ago, HumbleChief said: I've got some text stacked in my story pole dims and can't figure out how to make them more readable. Thanks 40 minutes ago, SHCanada2 said: I have to manually move them to look like this As Jason mentions. Click on the extension line till you see it highlighted and usually you will see a blue square I believe it is on the end by the marker. Select and hold and place the line where you want it exactly and a tail will follow it. 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 17, 2024 Share Posted January 17, 2024 5 hours ago, HumbleChief said: I have 2 buildings and the story pole seems to want to pull the correct data from one larger existing home (that will not be changed and is not part of the submittal) and not so great off the separate smaller building that is in the submittal scope of work. I'd like to pull the story pole info off the smaller building but it's not cooperating. I did this once. If I remember correctly, I set the storey pole to the other side of the building I wanted, so if there were two buildings and you wanted the left building, set the story pole to be on the left. I dont remember if the "highest ridge" worked or if I set that manually. And I probably had to set the reach 1 Link to comment Share on other sites More sharing options...
Solution SHCanada2 Posted January 18, 2024 Solution Share Posted January 18, 2024 I tried it on your plan. changed the reach and choose the right side. but it does have an errant "ridge line" but you can delete it. deleted: 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted January 18, 2024 Author Share Posted January 18, 2024 THANK YOU for the replies. I moved the story pole and its reach to the other side and it seemed to pick up everything Link to comment Share on other sites More sharing options...
