Missing ridge cap
Benny_G
I am currently planning reform works for a family home. Whereas on the tower's roof the ridge cap is automatically showing, on the main roof, it doesn't. Any idea why this is the case?
Benny Gasser
Architect
benny.gasser@gasser-architects.ch
Chief Architect Premier X15 on Apple MacBook Pro - 2TB SSD - AMD 5500M - 16GB
Hi Joe,
Thanks for your answer. I guess this should not be the case. As you may see on the picture, the roof is actually joined. The problem is however that on one side the two roof surface have a very large open joint and on the other side that the ridge cap is missing.
Have you tried to use the Join Roof Planes tool? Click on one of the roof plane edges you wish to join, hit '2', which is the quick key for that tool, then the edge of the other roof plane you want to join. You should see them merge, left click your mouse to confirm and hopefully Chief will build the ridge cap as well.
