Benny_G Posted January 17, 2024 Share Posted January 17, 2024 I am currently planning reform works for a family home. Whereas on the tower's roof the ridge cap is automatically showing, on the main roof, it doesn't. Any idea why this is the case? Benny Gasser Architect benny.gasser@gasser-architects.ch Chief Architect Premier X15 on Apple MacBook Pro - 2TB SSD - AMD 5500M - 16GB Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 17, 2024 Share Posted January 17, 2024 Most likely the roof planes are not joined. Link to comment Share on other sites More sharing options...
Benny_G Posted January 18, 2024 Author Share Posted January 18, 2024 Hi Joe, Thanks for your answer. I guess this should not be the case. As you may see on the picture, the roof is actually joined. The problem is however that on one side the two roof surface have a very large open joint and on the other side that the ridge cap is missing. Link to comment Share on other sites More sharing options...
OldBarnDesign Posted January 18, 2024 Share Posted January 18, 2024 Have you tried to use the Join Roof Planes tool? Click on one of the roof plane edges you wish to join, hit '2', which is the quick key for that tool, then the edge of the other roof plane you want to join. You should see them merge, left click your mouse to confirm and hopefully Chief will build the ridge cap as well. Link to comment Share on other sites More sharing options...
SNestor Posted January 19, 2024 Share Posted January 19, 2024 @Benny_G - you should post a plan or sample plan. Otherwise...all you will get are educated "guesses". Thanks! Link to comment Share on other sites More sharing options...
