Opondo Posted January 8, 2024 Share Posted January 8, 2024 hello,,,,how do i get to solve this type of auto exterior dimension to normal dimension Link to comment Share on other sites More sharing options...
Solution MPDesign Posted January 8, 2024 Solution Share Posted January 8, 2024 It looks like you started with a metric template. What type of dimension are you looking for? metric or imperial? Link to comment Share on other sites More sharing options...
Opondo Posted January 8, 2024 Author Share Posted January 8, 2024 I converted ft to metric after full plan auto exterior dimensions and that's what pop up Link to comment Share on other sites More sharing options...
Kbird1 Posted January 8, 2024 Share Posted January 8, 2024 4 hours ago, Opondo said: I converted ft to metric after full plan auto exterior dimensions and that's what pop up If you have only got 4 walls in the plan as yet ? simply restart the Plan in a Metric Template if that is what you want , it appears you are just displaying the secondary Dims and they are set to metric instead in an Imperial Plan, Chief comes with both. If you always work in Metric switch the Template used for New Plans in Preferences to the Metric Template so this doesn't happen again. M. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted January 8, 2024 Share Posted January 8, 2024 If you start a new plan with a metric (or imperial) template, it will always be a metric (or imperial) plan and there is no way that I know of to convert the units. You can display dimensions in either metric or imperial units (or both) but it won't change the units under the hood. 1 Link to comment Share on other sites More sharing options...
