Ed_Orum Posted December 29, 2023 Share Posted December 29, 2023 I drew this plan with 1/4"=1' for both dimensions and text. I saved the plan view. Then I duplicated the plan view, and gave it the name "1/8". I changed the default dimensions to 1/8"=1' for both dimensions and texts. I changed the text and dimensions from 1/4" to 1/8". I saved the plan view and closed it. When I opened the 1/4" Saved Plan View (the one I duplicated to make the 1/8" Saved Plan View) all of the dimensions and text were at 1/8". Even thought they are different saved plan views with different properties for the text and dimensions, they will not operate independently of each other. What did I do wrong? Thanks in advance, Lane Link to comment Share on other sites More sharing options...
Chrisb222 Posted December 29, 2023 Share Posted December 29, 2023 1 minute ago, Ed_Orum said: they will not operate independently of each other They will, if properly arranged. 1 minute ago, Ed_Orum said: What did I do wrong? Very difficult to pin down without more information. Especially a plan file. Otherwise just guessing. Link to comment Share on other sites More sharing options...
Ed_Orum Posted December 29, 2023 Author Share Posted December 29, 2023 Here is the plan. 12-10-2023 Revised Floor Plan.zip Link to comment Share on other sites More sharing options...
Chrisb222 Posted December 29, 2023 Share Posted December 29, 2023 8 minutes ago, Ed_Orum said: Here is the plan. 34 minutes ago, Ed_Orum said: Then I duplicated the plan view, and gave it the name "1/8". I don't see a Saved Plan View with "1/8" in the name.... Link to comment Share on other sites More sharing options...
Ed_Orum Posted December 29, 2023 Author Share Posted December 29, 2023 Here is the 1/8 saved plan view. Link to comment Share on other sites More sharing options...
DBCooper Posted December 29, 2023 Share Posted December 29, 2023 That saved plan view is not in the plan you posted. Link to comment Share on other sites More sharing options...
Ed_Orum Posted December 29, 2023 Author Share Posted December 29, 2023 hmmm, ok trying again with the plan 12-10-2023 Revised Floor Plan.zip Link to comment Share on other sites More sharing options...
Solution Chrisb222 Posted December 29, 2023 Solution Share Posted December 29, 2023 44 minutes ago, Ed_Orum said: hmmm, ok trying again with the plan Set your dimension default to "Use Layer For Text Style" and then in each Saved Plan View, select the appropriate text style in the Layer Display Options. You can do the same for Plain Text, which follows a similar scheme as Dimensions, but Rich Text will not follow those same rules. You can have different sizes per SPV when you create Rich Text, but it won't change size when you switch views because it obeys a different algorithm. Link to comment Share on other sites More sharing options...
Ed_Orum Posted December 29, 2023 Author Share Posted December 29, 2023 Ok, I will do that next. Link to comment Share on other sites More sharing options...
Ed_Orum Posted December 29, 2023 Author Share Posted December 29, 2023 Thanks, that did it. Now I'll try the text. Link to comment Share on other sites More sharing options...
Michael_Gia Posted December 31, 2023 Share Posted December 31, 2023 On 12/29/2023 at 5:09 PM, Ed_Orum said: Thanks, that did it. Now I'll try the text. I bet that after you went in and made changes to your saved plan view, you forgot to hit the “save plan view” button after closing the dialogue box. Also a good habit is to select “never save” at the bottom of the first panel of the Plan View dialogue box. 1 Link to comment Share on other sites More sharing options...
Ed_Orum Posted January 1, 2024 Author Share Posted January 1, 2024 Michael_Gia, Inconsistent with what i normally do, I actually did save each plan view. Why the "never save" in the plan view db? Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 1, 2024 Share Posted January 1, 2024 I use Never Save because I often make temporary changes that I don't want saved, and I dont want to be prompted. If I make a permanent change, which is rare, I simply save it manually. I also don't use the Remember Zoom option that you have checked. I had to turn that off while working on your plan because I prefer to switch between plan views without relocating. 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted January 4, 2024 Share Posted January 4, 2024 On 1/1/2024 at 11:22 AM, Chrisb222 said: I use Never Save because I often make temporary changes that I don't want saved, and I dont want to be prompted. If I make a permanent change, which is rare, I simply save it manually. I would just like to ask you if you also would like this behaviour for layer sets? That is, any temporary changes to a layer set do not modify the layer set unless you specifically hit a "save layer set" button. We don't have a, save layer set, button yet but don't you think that this is how layer sets should also work? Sometimes I just want to temporarily hide a layer but I don't want to alter the layer set and I don't want to create a new layer set for what I'm trying to do. Link to comment Share on other sites More sharing options...
Ed_Orum Posted January 5, 2024 Author Share Posted January 5, 2024 I always use the save button, and/or the save as with the same name. I would have to think about that for layer sets. Lane Link to comment Share on other sites More sharing options...
