RobWhite Posted December 21, 2023 Share Posted December 21, 2023 Can some help solve this? I want the window frame captured in the Room Elevation view. The window is positioned in the outer of the double wall system. This position is essential to the best practice for external window flashings. The window is displayed in the external elevation view but is on displayed in the internal room elevation view as shown below.. I have produced a double wall system. The wall frames are checked 'Frame through' in the Double Wall section of the Wall Specification box. as per the floor plan view. The design is an internal timber framed wall (90mm hatched) against the shed 150 steel purlins (150 grey) to create a double wall system. The window is position in the outer wall (or the grey section) which is automatically cut through the frame wall as shown below The room elevation view below is of the kitchen sink view, however the window frame is not showing because it is positioned in the outer wall. How do I get the room elevations to show the window? How do I resolve this? Link to comment Share on other sites More sharing options...
glennw Posted December 21, 2023 Share Posted December 21, 2023 Have you had a play with the Double Wall Options on the Casing panel of the door and window dbx? I assume that you have tried creating a single wall definition for your double wall? Link to comment Share on other sites More sharing options...
DBCooper Posted December 21, 2023 Share Posted December 21, 2023 I think this is an issue with using the wall elevation camera. It won't show any windows or doors in the outer wall of a double wall. I usually use a cross section camera instead and then setup the clipping to look the way I want. *edit* - I just figured out that it you make the wall "furred" instead of "frame through" you will see your windows and doors. Link to comment Share on other sites More sharing options...
RobWhite Posted December 22, 2023 Author Share Posted December 22, 2023 Yes, the Furring has worked correctly. Thanks! Link to comment Share on other sites More sharing options...
