ozaheman Posted December 10, 2023 Share Posted December 10, 2023 hi, Any idea to create grooves on the walls, as image attached? Link to comment Share on other sites More sharing options...
glennw Posted December 10, 2023 Share Posted December 10, 2023 Try Wall Material Regions? Link to comment Share on other sites More sharing options...
ozaheman Posted December 10, 2023 Author Share Posted December 10, 2023 9 minutes ago, glennw said: Try Wall Material Regions? Wall material adds thickness, i need recessed grooves Link to comment Share on other sites More sharing options...
Solution glennw Posted December 10, 2023 Solution Share Posted December 10, 2023 7 minutes ago, ozaheman said: Wall material adds thickness Not necessarily so. Keep playing, particularly with Cut Finish Layers of Parent Object. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 11, 2023 Share Posted December 11, 2023 2 hours ago, glennw said: Keep playing, particularly with Cut Finish Layers of Parent Object. this should work just fine for recessed grooves ( it also works got board and batten , with the "cut finish layers" setting ) Assuming the version you have , has the Material Region on the Wall Menu? ( not in your Sig.) M. Link to comment Share on other sites More sharing options...
CharlesVolz Posted December 11, 2023 Share Posted December 11, 2023 Also can use molding polylines set 1/32 to outside of wall face. Use black (my preference) or airgap material. I suggest using an exterior room molding polyline (one polyline with multiple stacked rectangular-shaped moldings) to keep the molding(s) out of the way while working. Link to comment Share on other sites More sharing options...
