Removing a ceiling to create exposed rafters for screened porch.
TheDeckGuy71
23 minutes ago, solver said:
As the program continues to evolve, knowing what software you are using helps others provide the best answers/suggestions. Here is a thread showing how to place that info into your signature so it's always available.
Open the room, review the options on the Structure panel -- one should be obvious.
David,
    Thanks for the advice, I'll get to that shortly.  In the mean time I am using Chief Architect X15 on an Alienware M-18 with RTX 4090
I built the structure as a deck and placed the roof over it and I just want to remove the ceiling material and show the exposed rafters.
Any feedback you could provide would be greatly appreciated.
Thanks so much,
Randall Morgan
As Joe said, uncheck "Ceiling Above This Room," but also you will need to go into the Roof dialog and delete the ceiling layers:
1060953578_ScreenShot2023-12-06at11_25_39AM.thumb.png.a4ef461048792715179a3aa23d3aec23.png
Then make sure you have "Framing, Roof Rafters" layer turned on in your camera view:
900959899_ScreenShot2023-12-06at11_26_49AM.thumb.png.5cebb06626c59c513188b20798af9e0d.png
