QualicoreHomes Posted November 18, 2023 Share Posted November 18, 2023 Hello, I would like to add a column to my window schedule that specifies the wall thickness, is that a possibility? I have a project with several different wall thicknesses so I thought it would be nice to add a column where it would indicated whether the wall is a 2x4, 2x6 etc. Thanks for any help!! Link to comment Share on other sites More sharing options...
QualicoreHomes Posted November 18, 2023 Author Share Posted November 18, 2023 Thanks for that Solver! I'm not familiar at all with macros or how to write them. If you are interested in writing one for me let me know what you would charge for that. Thanks again! Link to comment Share on other sites More sharing options...
joey_martin Posted November 19, 2023 Share Posted November 19, 2023 Just add a custom column in the schedule. Simple as that. 1 1 Link to comment Share on other sites More sharing options...
QualicoreHomes Posted November 20, 2023 Author Share Posted November 20, 2023 Thanks for that Joey, My apologies for my ignorance but I can't get it. Added a column in the schedule and a custom field in the object info but no luck in getting a wall thickness. Am I totally on the wrong track here or missing something small in the field value? Thanks for the help! Link to comment Share on other sites More sharing options...
QualicoreHomes Posted November 21, 2023 Author Share Posted November 21, 2023 Thank you, that worked! Link to comment Share on other sites More sharing options...
robdyck Posted November 22, 2023 Share Posted November 22, 2023 Gerard, if you're using a typical PVC or Aluminum window with a nailing flange, the frame depth or wall thickness may provide slightly confusing information to a supplier. I could see my phone ringing with questions about why I'm specifying a 7" jamb instead of a 6 9/16" jamb. Seeing as in our region, jamb depth is measured inward from the nailing flange, the frame depth or wall thickness could have the exterior layers removed from the reported value. This is simply done using a manual calculation added to the macro, but it does mean that you'll need to know the exterior wall cladding layer thickness and subtract those from your reported value. Perhaps @solver knows a way to include a macro that automatically reports the wall thickness, minus the exterior cladding thickness, plus 1/16" for construction tolerance. 1 Link to comment Share on other sites More sharing options...
QualicoreHomes Posted December 13, 2023 Author Share Posted December 13, 2023 Hello Rob, Sorry, I did not see your reply till now. Yes I agree and I was hoping to get something as simple as just showing whether the wall, in which the window is installed, is a 2x4, 2x6 or 2x8 wall for the same reason as you indicated. Would there be a possibility to report the wall thickness like that? Link to comment Share on other sites More sharing options...
robdyck Posted December 13, 2023 Share Posted December 13, 2023 On 12/13/2023 at 1:32 PM, QualicoreHomes said: Hello Rob, Sorry, I did not see your reply till now. Yes I agree and I was hoping to get something as simple as just showing whether the wall, in which the window is installed, is a 2x4, 2x6 or 2x8 wall for the same reason as you indicated. Would there be a possibility to report the wall thickness like that? Expand If your walls are named very nicely, then a simple macro to include in the OIP would be: %containing_wall.automatic_description% 1 Link to comment Share on other sites More sharing options...
QualicoreHomes Posted December 14, 2023 Author Share Posted December 14, 2023 Thank you very much, I will have to rename some of the walls but that should work perfectly! Many thanks!! 1 Link to comment Share on other sites More sharing options...
