GeneDavis Posted October 23, 2023 Share Posted October 23, 2023 I cannot find where to do this. Gimme a hint, please. I'd like to do it in defaults so as not to have to go wall by wall already built. I can change the material to OSB vertical in the default for exterior wall sheathing, but where is the key for the size? Link to comment Share on other sites More sharing options...
Chrisb222 Posted October 23, 2023 Share Posted October 23, 2023 11 minutes ago, GeneDavis said: I cannot find where to do this. Gimme a hint, please. I'd like to do it in defaults so as not to have to go wall by wall already built. I can change the material to OSB vertical in the default for exterior wall sheathing, but where is the key for the size? Material Definition > Materials List tab: You'll probably want to make a new material with this new size definition. Link to comment Share on other sites More sharing options...
GeneDavis Posted October 23, 2023 Author Share Posted October 23, 2023 Thanks! Link to comment Share on other sites More sharing options...
rgardner Posted October 23, 2023 Share Posted October 23, 2023 2 hours ago, GeneDavis said: I cannot find where to do this. Gimme a hint, please. I'd like to do it in defaults so as not to have to go wall by wall already built. I can change the material to OSB vertical in the default for exterior wall sheathing, but where is the key for the size? 2 hours ago, Chrisb222 said: Material Definition > Materials List tab: You'll probably want to make a new material with this new size definition. BTW you can also do this with drywall by defining your sheet size for 4x8, 4x12, 4.5x12, 5x12, etc. Link to comment Share on other sites More sharing options...
