Dimension Fraction Issue
Steve_Nyhof
Does anyone know how to turn off or in some way fix this odd fraction issue? I feel embarrassed having this on my plan and having to make a framer figure out what 2/3" is - somewhere between 5/8" and 11/16". - I have my fraction set to 1/16" as smallest so figure it should round up or down. ???
2 hours ago, stevenyhof said:
Sorry, wrong plan
This is correct - Thank you!
It's doing that because your Dimension Default is set to Distance Rounding. Change the Primary Format to "Grid Rounding" and the problem goes away.
1394955459_ScreenShot2023-10-05at1_46_14PM.thumb.png.043182cf265e4788a233ae6ffcfb915b.png
And I would absolutely urge you to change your dimension defaults. Most of your user dim defaults beginning with an * are set to use Distance Rounding, which has the potential to introduce dimension errors in your dimension string. (You also should check "Use Greatest Common Divisor" instead of "Use Closest Fraction.)
From Help:
828197579_ScreenShot2023-10-05at1_47_37PM.thumb.png.0eaf807713b92551c698b68b29042271.png
From Help:
Thank you - I will fix this. I don't like to make the framers think.
