JamieW_Campbell Posted September 30, 2023 Share Posted September 30, 2023 Hello! I'm on X14 and I'm not sure why my garage appears to be floating. I assume I need to make an adjustment to the foundation? Any suggestions would be greatly appreciated. Thank you! Link to comment Share on other sites More sharing options...
DBCooper Posted September 30, 2023 Share Posted September 30, 2023 It looks like you didn't actually build the foundation. Either that, or you didn't rebuild it after you made changes. Or maybe you messed up your room (or room structure) settings that could be causing that. If you want something more than random guesses, it is usually best to post the plan. Link to comment Share on other sites More sharing options...
ericepv Posted September 30, 2023 Share Posted September 30, 2023 And if you did build a foundation, make sure that layer is switched on. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 30, 2023 Share Posted September 30, 2023 Also is floor in this room checked Link to comment Share on other sites More sharing options...
