Can't get edited 2D CAD block to work with symbol
GeneDavis
A pedestal sink in the Chief Kohler manufacturer library has incorrect 3D, so I got a good one from Kohler and inserted it.  The generated 2D CAD block is inadequate for 2D plan view, so I opened it in CAD Block management.
The images below show the plan view with the auto-generated CAD block that doesn't pick up the lines from Kohler's 3D, a 3D view, how the block looks in the dialog box, and how it looks after I edited it in CAD.  Why are my edits not taking?
Sometimes when the generated 2d block doesn't look quite right you can get better results by adjusting the smoothing angle.
From the middle picture above, it is impossible to tell if you actually choose the cad block your are editing in the bottom picture.  My guess is that you didn't.  If you did but it doesn't display the same, then you probably need to post the plan.
