Chele555 Posted September 16, 2023 Share Posted September 16, 2023 When I select an object, I can move it right with the right arrow key on my keyboard. But I can't move objects left. Is there a setting somewhere? TIA! Link to comment Share on other sites More sharing options...
Chopsaw Posted September 16, 2023 Share Posted September 16, 2023 No setting for that sorry. It could be a keyboard issue or perhaps you are bumping into something on the left ? Check the up and down keys to see if they are ok. Link to comment Share on other sites More sharing options...
Chele555 Posted September 16, 2023 Author Share Posted September 16, 2023 Yep, up down and right work. Just not left , so strange. Tried two keyboards, will contact tech support. Thanks! Link to comment Share on other sites More sharing options...
DBCooper Posted September 16, 2023 Share Posted September 16, 2023 Or, if you don't want to wait, you could try posting the plan on the forum. Then someone can see if they have the same problem and maybe figure out what is blocking the move. I'm guessing like chopsaw that you have something that is blocking the move. Although usually when this happens you can move it right and then move it back left until it hits whatever is blocking it. Of course it could always be something else, like somehow you accidently mapped the arrow key to do something other than move? Also, just as an fyi, there are lots of ways to move things other than using the left arrow. Using the transform/replicate dialog or typing in a value for a dimension are other ways of moving an object that can usually ignore any blocking objects. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 17, 2023 Share Posted September 17, 2023 On 9/16/2023 at 8:56 PM, Chele555 said: Yep, up down and right work. Just not left , so strange. Tried two keyboards, will contact tech support. Thanks! Expand What is the "Object" as some have Attributes that stop them when they touch a wall or a CAD object ........even if you can't see it ...... as DB mentioned we need more info and/or the Plan to diagnose.... M. Link to comment Share on other sites More sharing options...
