GeneDavis Posted September 10, 2023 Share Posted September 10, 2023 To model a fridge panel, I used a partition, made it my preferred size, it shows nicely in 3D and in plan, but I cannot get it to report to the cabinet schedule. My term fridge panel is for the full height 26.5" depth x 1.5" width panel adjacent a fridge. Pic attached. The base fillers, wall fillers, full height fillers, all will report, but not the partition. I dropped one elsewhere in the plan to see if a newly placed one would report, but no. Link to comment Share on other sites More sharing options...
DBCooper Posted September 10, 2023 Share Posted September 10, 2023 You need to make sure partitions are checked in the categories to include on the schedule general panel. I think partitions are always turned off by default (unless you already changed them in your cabinet schedule defaults). 2 Link to comment Share on other sites More sharing options...
Kbird1 Posted September 11, 2023 Share Posted September 11, 2023 I think in X15 at least they are all on by Default in both the Cabinet Schedule and in the Plan Defaults (for Partitions+Shelves etc, have a play in the x15 Residential Template), though I am not sure that was the case in earlier Versions, so you may need to fix that in your Template, if started in an earlier version, as I do see to remember it as shown by DB. (bottom 4 unchecked) Mick. Link to comment Share on other sites More sharing options...
