Changing the tolerance of cabinet labels
saraolson
1 hour ago, saraolson said:
Is it possible to change the tolerance of the cabinet labels?  Cabinets that are 17 1/2" wide are currently labeled as 18" wide.
Thank you
Sara
(Please fill out your signature with version, some computer info helps along the way-there are posts detailing this.)
Yes
by setting default label to "specify label" From there it depends on which version of Chief you are using.
Once setting to specify label you need to have a nomenclature identifier, Like B for base, followed by a dimension macro set to the tolerance you want. This gets tricky when that nomenclature changes - like to 3DB.
IF in X14 or above look for information on "number formatter: in the forum to see how to write a dimension macro.
There are a couple of folks on the forum who sell a cabinet label macro that can account for "some" nomenclature. You could look into that- likely not expensive. BUT FWIW what is out there would not work for any of the brands of cabinet that I worked with. So find out what setting they offer for that before getting into it.
There are ways to shortcut some of the process using with a library of user configured cabinets with correct starting nomenclature for each. That can be used with the "replace from library" tool or with style palettes -both of which are separate topics.
