saraolson Posted September 6, 2023 Share Posted September 6, 2023 Is it possible to change the tolerance of the cabinet labels? Cabinets that are 17 1/2" wide are currently labeled as 18" wide. Thank you Sara Link to comment Share on other sites More sharing options...
MarkMc Posted September 6, 2023 Share Posted September 6, 2023 1 hour ago, saraolson said: Is it possible to change the tolerance of the cabinet labels? Cabinets that are 17 1/2" wide are currently labeled as 18" wide. Thank you Sara (Please fill out your signature with version, some computer info helps along the way-there are posts detailing this.) Yes by setting default label to "specify label" From there it depends on which version of Chief you are using. Once setting to specify label you need to have a nomenclature identifier, Like B for base, followed by a dimension macro set to the tolerance you want. This gets tricky when that nomenclature changes - like to 3DB. IF in X14 or above look for information on "number formatter: in the forum to see how to write a dimension macro. There are a couple of folks on the forum who sell a cabinet label macro that can account for "some" nomenclature. You could look into that- likely not expensive. BUT FWIW what is out there would not work for any of the brands of cabinet that I worked with. So find out what setting they offer for that before getting into it. There are ways to shortcut some of the process using with a library of user configured cabinets with correct starting nomenclature for each. That can be used with the "replace from library" tool or with style palettes -both of which are separate topics. Link to comment Share on other sites More sharing options...
DBCooper Posted September 6, 2023 Share Posted September 6, 2023 If it's just a one-off cabinet, I would just type in the label you want. If all you want a more accurate width, then just use the %width% built in macro. Link to comment Share on other sites More sharing options...
Chrisb222 Posted September 6, 2023 Share Posted September 6, 2023 In other words, no, you can't change the tolerance of the automatic label. There's no setting for that. You could try posting a request for that feature in the Suggestions forum, just don't be in a hurry. Link to comment Share on other sites More sharing options...
