GeneDavis Posted September 3, 2023 Share Posted September 3, 2023 I had this OK before but not now. See the pics. The building has a slab foundation I have drawn with foundation wall footings to create the thickened edges. As can be seen, one of the walls, specified just like the others, builds atop the slab and runs up to the roof. How can I fix this? The footing wall opposite it, where the post is bearing, has the same spec definition but is not rising up off the slab. Both it and the front footing wall are behaving as I want. All three bounding walls are room definition walls and they define the porch. All three are under a roof. There is no ceiling, as the roof soffit is the ceiling. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 3, 2023 Share Posted September 3, 2023 Long shot would be to drag the front wall over the rogue side wall and see what happens. Link to comment Share on other sites More sharing options...
GeneDavis Posted September 3, 2023 Author Share Posted September 3, 2023 I think I can share this using Google Drive. Let's see if this works. https://drive.google.com/file/d/1IukXwD7wdG0D7Jv8qhv98ET-XZ6qL1FH/view?usp=drive_link Link to comment Share on other sites More sharing options...
Kbird1 Posted September 3, 2023 Share Posted September 3, 2023 1 hour ago, GeneDavis said: I think I can share this using Google Drive. Let's see if this works. https://drive.google.com/file/d/1IukXwD7wdG0D7Jv8qhv98ET-XZ6qL1FH/view?usp=drive_link It's not shared ( permission needed ) with the "Public" Gene........... M. Link to comment Share on other sites More sharing options...
GeneDavis Posted September 3, 2023 Author Share Posted September 3, 2023 Try this. https://drive.google.com/file/d/1IukXwD7wdG0D7Jv8qhv98ET-XZ6qL1FH/view?usp=sharing Link to comment Share on other sites More sharing options...
Kbird1 Posted September 3, 2023 Share Posted September 3, 2023 50 minutes ago, GeneDavis said: Try this. https://drive.google.com/file/d/1IukXwD7wdG0D7Jv8qhv98ET-XZ6qL1FH/view?usp=sharing Link Working now.......... In this Plan I am seeing a Normal Exterior Wall buried in the offending Footing Wall going to the Roof......... I had an idea earlier and it worked but admit I'm not 100% sure why........... I set the Footing wall to an Attic Wall and it worked... and deleted the Normal Siding wall which also removed the Attic wall above it. Link to comment Share on other sites More sharing options...
GeneDavis Posted September 3, 2023 Author Share Posted September 3, 2023 That normal wall needs to be there and I had it all successfully modeled when I took this shot. And this rear elevation. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 3, 2023 Share Posted September 3, 2023 1 minute ago, GeneDavis said: That normal wall needs to be there and I had it all successfully modeled when I took this shot. Oh....... then don't delete it I thought no wall that side was the "Look" you wanted. M. Link to comment Share on other sites More sharing options...
GeneDavis Posted September 3, 2023 Author Share Posted September 3, 2023 Guess I'll try that, Eric. More than just a few clicks, though. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 3, 2023 Share Posted September 3, 2023 14 minutes ago, GeneDavis said: Guess I'll try that, Eric. More than just a few clicks, though. So the Attic Wall setting doesn't work for you? I might need to open it and try again....... ** Fix still seems to work for me, but Balloon it up on the Structure Tab. M. Link to comment Share on other sites More sharing options...
GeneDavis Posted September 3, 2023 Author Share Posted September 3, 2023 The attic thing seems to take away the ballooning footing wall, but there's no footing under the right edge of the porch foundation slab. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 3, 2023 Share Posted September 3, 2023 1 minute ago, GeneDavis said: The attic thing seems to take away the ballooning footing wall, but there's no footing under the right edge of the porch foundation slab. Oh I didn't notice that, it seems it stops the wall coming onto the next level, as it there on level 0, any reason not to use a Slab with Footing for the Porch Slab instead of Walls. M. Link to comment Share on other sites More sharing options...
GeneDavis Posted September 3, 2023 Author Share Posted September 3, 2023 OK, rebuilt the foundation and it fixed the ballooning stoop edge footing wall. The foundation plan I can CAD edit to make it look right, and it has a couple problems in 3D when I look under it, but all is good now for the con docs. Look at the attic portion of the stoop roof support wall, how its end finish ain't there. I had to fix the wall below using a room divider wall for the outboard end of the wall to butt to, so maybe this same hack will fix the attic part. If not, a solid will patch it. Link to comment Share on other sites More sharing options...
GeneDavis Posted September 3, 2023 Author Share Posted September 3, 2023 The attic wall end needed a patch done with a solid, but she's good now. Thanks, Eric. Thanks, Mick. Off to the neighborhood picnic in the lovely mountain glen. Third generation families property owners here going back over 110 years. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 4, 2023 Share Posted September 4, 2023 18 hours ago, GeneDavis said: Look at the attic portion of the stoop roof support wall, how its end finish ain't there. Did Balloon wall up not work eliminating the need for the Attic wall ? just curious as I can't test this in the Plan you uploaded. Mick. Link to comment Share on other sites More sharing options...
